Old 12-26-2013, 05:59 PM   #1
Registered Boxster abuser
healthservices's Avatar
Trans fluid leak
I thought it was the front pump seal but not so sure it is now. I see a lot of oil at the electrical connector under the bell housing.
similar to the Mechatronic sleeve leaks that BMWs get in their ZF transmisions.
Anyone see this type of leak?
Old 12-27-2013, 12:06 AM   #2
Ha, I guess it does not matter anymore now, after removing the converter it looks that the trans has been messed with in the past. It looks like I have to decide to rebuild the tranny myself or get a used one. Hmmm.
Sent from my SM-T310 using Tapatalk 4
Old 12-27-2013, 01:01 AM   #3
Yes these bolts have been f' up by someone.
Sent from my SAMSUNG-SGH-I317 using Tapatalk
Old 01-06-2014, 10:55 AM   #4
Well the bushing in the pump where the converter rides in was replaced incorrectly and does not fit the converter properly. I replaced the pump case with a new bushing, and all is well again.
Old 01-07-2014, 03:58 PM   #5
woodsman's Avatar
so that wasn't JB weld under a few of those bolts???
Old 01-08-2014, 10:29 AM   #6
Some type of silicone I fear but nothing in the case or filter.
Old 01-16-2014, 11:47 PM   #7
The seal could be damaged; the bearings could be bad…
riyarobin is offline   Reply With Quote
Old 01-16-2014, 11:48 PM   #8
Asmiley's Avatar
How do I post a new question?
Asmiley is offline   Reply With Quote
Old 01-17-2014, 09:38 AM   #9
