Old 02-09-2006, 02:40 PM   #1
Steve,
I have had code 1128 before and it occurred after I did the Evo intake and B and B exhaust. I dont have a cat bypass. I cleared the 1128 once and it hasnt returned.. I have had a 1127 code for MAF or air fuel mix metering issue. I cleaned the MAF sensor and reset it this weekend with good results. You should disconnect the battery for 20 or so minutes and then reconnect it. Start the car and let the computer re-learn the system with the new intake and exhaust. This may correct the fuel air mix a little. Dont worry about the car running rough for a few minutes after you first start it. This is normal and will correct itself. Maybe this will help!
P.S. dont forget to get your radio code before disconnecting the battery. You will
need it when you reconnect power.
Best of luck!
Joe DiMonte
2001 Boxster S
Triple Black
AUDIOGUY is offline   Reply With Quote
Old 02-09-2006, 03:19 PM   #2
OK...there have been lots of posts on O2 codes and my 2000S Just had the 4th replaced this last weekend. Its good that you cleared the codes. If they return like mine did, you either have a bad O2 or MAF from my experiences. Start with the O2 sensors and test as MNBoxster has described in an earlier thread. Find the bad one and replace it. Chances are that withen 2 weeks of replacing one you will get another code because the others are much older and can't keep the computer happy. Result...you will end up replacing all 4 sooner than later.
How many miles do you have? I had 53,000 and all previous threads noted the O2 sensors will last approx. 60,000 miles. So I was in the ballpark for replacing mine. My MAF also went out. This also set O2 codes but the dealership figured it was the MAF initially due to the fact that I had a terrible idle on cold starting and rough idle throughout my drive. Further tests proved it was the MAF. The O2 will run you approx. 200 each and the MAF could be 300 depending on where you buy your parts. Replace them yourself and save big money on easy labor!
2000 Porsche Boxster S
2007 Lexus RX350
xclusivecar is offline   Reply With Quote
Old 02-09-2006, 08:10 PM   #3
Originally Posted by xclusivecar
OK...there have been lots of posts on O2 codes and my 2000S Just had the 4th replaced this last weekend. ...Find the bad one and replace it. ...The O2 will run you approx. 200 each and the MAF could be 300 depending on where you buy your parts. Replace them yourself and save big money on easy labor!
Replace all four 02 sensors at the same time. The reaction time of a new one mixed with old ones will throw a CE light and cause havoc.
www.oxygensensors.com sells them for $119 each. Just bought four. Replacement is easy. Took me 45 minutes and I was working slowly.
Old 02-10-2006, 01:21 PM   #4
I agree with RandallNeighbour 100%. Change all 4 if possible. All of mine were covered under an extended warranty but they would only cover each individual one as they expired! No cash out of pocket, but LOTS of time in and out of the dealership!
BTW--RandallNeighbour, is that for an OE (Bosch?) sensor? Thats a great price and I believe on my invoice that the dealership would have billed me $245/sensor had I not had the warranty! Makes me rethink the extended warranty I purchased since you can buy parts rather cheap online if you look and can do the labor yourself! Oh well...my first Porsche and didn't want to take the chance of something happening since everything you hear in the auto world is how expensive and how hard these cars are to work on. Obviously not in the Boxsters' case. This has been the easiest car I have ever done maintenance on!
2007 Lexus RX350
Old 02-11-2006, 09:09 AM   #5
Yup, Bosch sensors with the proper plugs on the end, just like from the factory. And they work great. No CE lights or problems to date.
