Old 11-21-2013, 01:40 PM   #7
Steve Tinker's Avatar
teleski....
I assume you "burped" the cooling system by lifting the pressure relief valve chromed ring mounted under the coolant resevoir filler cap !!
I found its was best to leave the valve in the open position for a couple of heat cycles to rid the system of small pockets of trapped air.
2001 MV Agusta F4.
