Old 01-19-2014, 01:20 AM   #181
Steve Tinker's Avatar
Now lets see the "opposition" jump on the bandwagon & start the diatribe scramble to poo-poo this great idea.....
2001 MV Agusta F4.
Old 01-19-2014, 05:08 AM   #182
Engine Surgeon
It would have been so much better for them if they would have chosen to work with us, rather than against us. Best friend or worst enemy; there's only two choices when dealing with my breed. We never quit, we never give up and we live for resistance.
Thanks Jake. I am amazed - again
Just wait till you see what I have saved for last.
US Patent 8,992,089 &
US Patent 9,416,697
Old 01-19-2014, 05:48 AM   #183
Jake,
Nice selfe!
Old 01-19-2014, 06:18 AM   #184
Engine Surgeon
Originally Posted by Van914 View Post
Jake,
Nice selfe!
I didn't even have to photoshop it! Although I think I have gotten too much sun lately...
US Patent 9,416,697
Old 01-19-2014, 08:55 PM   #185
After I exhaled I am not so high on grease anymore.
While testing the seals on the Nachi bearing, I was surprised to feel and hear any clunking from the bearing even with grease in it. I get a lot of that when spinning the bearings dry, but didn't expect any when greased, but there is still some of that going on even with grease. I assume it is bits of debris getting caught between the balls and race, or the cage getting in a jam.
After a couple hours, what started out as a golden honey-like grease has turned to black goo. I am now thinking the grease may not be as good a lubricant as a continuous flow of oil. So I think I will go back to the oil route.
One thing I do know, before my new bearing goes into my Box, it is going to be run in grease for 3 minutes, cleaned and re-greased, run for 20 minutes, clean and re-grease, then run for 3 hours on the test stand before being oiled and installed.
It's all bad
Walter White is offline   Reply With Quote
Old 01-19-2014, 09:10 PM   #186
Engine Surgeon
If feeding directly into the bearing you might want to do a Patent search first.
Thats the case for anyone wanting to develop an IMS fix, don't assume that its not in existence just because you haven't heard that it is.
And no longer is something a quality product just because its patented, there are instances where the bad ideas are protected simply as flanking maneuvers.
US Patent 9,416,697
Old 01-20-2014, 05:42 PM   #187
Beginner
Jamesp's Avatar
[QUOTE=Walter White;381890]So I think I will go back to the oil route.QUOTE]
Grease is used successfully in many bearings. Ask just about any electric motor or wheel you know.
But if you want to go oil, try to skip the hoses and fittings and go straight to the source. You should be able to introduce oil directly through the oil pump drive key into the IMS shaft, and I have the start of an idea of how to do it with a very minimum of structural compensation to the drive key. Another item, I keep seeing things about sealing the IMS, a "lightly pressed" assembly. I do a lot of crazy things but making a pressure vessel that undergoes frequent thermal / pressure cycles (while bathed in oil and undergoing structural cyclical stress and strain no less) out of a lightly pressed assembly is not one of them. My sense is those forces are likely to take that assembly apart over time.
2003 S manual
Old 01-20-2014, 08:35 PM   #188
Yeah, I don't really want to run pipe or tubing anywhere.
But I am pretty sure I want to feed my bearing indirectly with oil. The cooler and cleaner the oil the better.
I have been testing the partially open seal design and so far, measuring the oil that comes out, I calculate that 10cc/min or less may be enough. I may see if some design changes to the seal will reduce consumption. But the most important thing is to keep the oil moving through to keep the bearing clean.
I can't remember my exact calculations on the pressure of sealing the IM shaft but I think it was a difference of 30 psi from 0 to 300*F. So if the shaft were sealed with an air temperature of 70*F, the maximum pressure it would see is about +23 psi, and a minimum of about -7 psi. Since the plug would be near the end of the shaft, I think the sprocket assembly outside the shaft will provide plenty of support. I don't think it would be as stressed as if it were near the middle of the shaft. I think a plastic cam plug with some Loctite or similar adhesive would probably work. Maybe install two plugs, back-to-back.
It's all bad
Old 01-21-2014, 03:59 AM   #189
Beginner
Jamesp's Avatar
If a hole is drilled through a loaded shaft, the most load efficient way to do it is along the axis of the shaft. Drilling a hole through the IMS bearing bolt would require a larger bolt diameter than normal to maintain load carrying capacity.
2003 S manual
Old 01-21-2014, 08:02 AM   #190
Actually, the hole does not go through the bolt shank, only the shoulder.
I think .032" should do.
But I was considering making a larger bolt and going through the cener of the shank. It would actually be easier and stronger. It would only require drilling the flange shoulder bigger. Much like the later model flange.
I PM'd you yesterday.
It's all bad
Old 01-21-2014, 02:49 PM   #191
Beginner
Jamesp's Avatar
got the pm - What graphics program do you use?
2003 S manual
Old 01-21-2014, 03:44 PM   #192
Beginner
Jamesp's Avatar
Here was the thought, sizing the oil hole to allow only a tiny bit of oil (very small hole) would be critical. Additionally the small hole would have a small effect on key strength. Key material could be upgraded if that were found to be a problem.
2003 S manual
Old 01-21-2014, 06:39 PM   #193
Jager's Avatar
DVD's on how to rebuild a M96?? I have been patiently waiting.
Jäger
300K Mile Club
Old 01-21-2014, 06:46 PM   #194
James, I use a very sophisticated graphics program that takes a very powerful computer and extensive training. MS Paint. I am Paint certified.
Can this be done with the engine in the car?
I have another question for you. Is it possible to get a wrench on the IMSB bolt nut when the flywheel, clutch and tranny is installed if there were an access port in the bell housing. Or is the flywheel just too close. Is there any recess in the back of the flywheel that might allow access to that nut with a wrench when the flywheel is in a certain position.
It's all bad
Old 01-21-2014, 07:06 PM   #195
Beginner
Jamesp's Avatar
Should be able to be done with the engine in the car.
No way I can see of getting the the IMSB with tranny and flywheel installed. No place for an access port - its all load bearing/ primary structure
2003 S manual
Old 01-21-2014, 07:18 PM   #196
Engine Surgeon
You might want to lay your hands on one of these engines before attempting to save the world. Having a passionate understanding of every part is the key to solving these problems.
BTW- Their won't be any M96 DVDs, only my assembly manuals. DVDs can't be updated as we develop and understand more.
US Patent 9,416,697
Old 01-21-2014, 07:26 PM   #197
So the oil pump can be removed through the access panel in the car interior?
Incoming PM
It's all bad
Old 01-22-2014, 04:41 PM   #198
Beginner
Jamesp's Avatar
I never really looked at taking the oil pump out throught the access panel. I've been more of a "just drop the engine and go to town" kind of a mechanic, so I'm very limited in my knowledge of working on the engine while it's actually in the car. Dropping the engine the first time was a hassle, the second time, not so much. I'm sure as I learn, it will become second nature. From what little I've done, there is a world of difference between trying to work on it in the car, and out on a stand. My sense is that to leave the engine in the car and remove the oil pump getting the front engine mount out of the way would be a benefit. At that point dropping the front down for more clearance seems logical. Someone else who has actually done that can chime in if they have a mind to.
2003 S manual
Old 01-22-2014, 05:52 PM   #199
JAAY's Avatar
if you guys are really going to dive into this, the engine is easier to drop than working with it in there. Don't be scared. Just take it out.
Old 01-22-2014, 06:03 PM   #200
Engine Surgeon
Incoming PM
No way, its way too low in the chassis and the oil pump body is part of the front console. To remove the console in the car is a royal ********************, I have done it once and will never do it again.
US Patent 9,416,697
