Old 11-03-2013, 08:24 AM   #1
jakesbox
trimer's Avatar
new errors
changed the plugs and the coils. took car out. did not throw a CEL but there was an obvious misfire or something going on. car ran good other wise but getting on it at one point it shuttered almost like it was cutting out.
Checked on the durametric and it told me no fault codes...but when I looked at the ready status section I saw this. Any ideas, thoughts, help, etc?
Old 11-03-2013, 08:29 AM   #2
jakesbox
trimer's Avatar
Well, I hav4 tried every way to Sunday to get this picture to work but basically when I click on the ready status it says
Catalytic converter efficiency - Failed
Fuel Tank Ventilation - Failed
Secondary Air System - Pass
Oxygen Sensors - Pass
Oxygen Sensor Heater - Pass
Old 11-03-2013, 08:52 AM   #3
jakesbox
trimer's Avatar
Ps - gas cap seal is in good shape no tears...
Old 11-03-2013, 03:17 PM   #4
woodsman's Avatar
Either way it's important to note there's no codes. One would think that if there was substantial problem a code would be thrown. Does it stumble just when applying throttle or while cruising? Bummer you've still got issues after all those new parts.
Old 11-03-2013, 03:46 PM   #5
jakesbox
trimer's Avatar
I took it back out and really jumped all over it. It did not miss or stumble on a 30 minute ride like it did right after I replaced everything. Plugged durametric back in and still no codes but still showing under the ready status ...
What do those things mean??
Old 11-03-2013, 06:23 PM   #6
linderpat's Avatar
did you maybe bump the injestor harness? Sounds like an injector connection may be loose or off. Not sure of the proximity of the injector connections to the plug/coil set up.
Ed
Pittsburgh, PA
78 5 spd 928 Blumaxx (in Hemmings S & E issue #100)
85 928S garnet red stock daily driver
06 Mustang GT Legend Lime and modified to go even faster
linderpat is offline   Reply With Quote
Old 11-03-2013, 07:10 PM   #7
Jager's Avatar
trimer,
Did you disconnect your battery or reset trouble codes using your Durametric recently?
Jäger
300K Mile Club
Old 11-03-2013, 07:18 PM   #8
jakesbox
trimer's Avatar
trimer,
Reset fault codes for the misfires a couple days ago. Installed the plugs and coils today. No more fault codes just what I have listed in the ready status.
Old 11-03-2013, 07:26 PM   #9
Jager's Avatar
It will take a few driving cycles and a few miles for these systems to verify status after a reset... Just drive your Boxster a few more times and the Catalytic converter efficiency and Fuel Tank Ventilation will complete the self check. It could take 60 miles or more of driving, and a few start-up/warm-up cycles.
Jäger
300K Mile Club
Old 11-04-2013, 03:54 AM   #10
jakesbox
trimer's Avatar
Thanks Jager. I plan to put some miles on this week and will check again!
