Old 10-31-2013, 06:05 AM   #1
jaykay's Avatar
Water Pump Change - coolant loss
Just changed my water pump and had a vacum fill. I have had to add 1.5 L of premix since after driving for a total of two hours
Is this normal or do I have a problem!!
986 00S
Old 10-31-2013, 06:26 AM   #2
Normal. It's burping.
Old 10-31-2013, 07:01 AM   #3
jaykay's Avatar
Thanks for your feedback!
I had assumed that the pressure fill would limit the top up to 0.5 L or so.......live and learn
986 00S
Old 10-31-2013, 03:17 PM   #4
pjq
yes a good vacum fill should have eliminated that problem.
A good burp is ok but now monitor your coolant level and temp.
Old 11-01-2013, 05:42 AM   #5
After filling your system, you can then use the Uview tool to pull vacuum again to draw out any remaining air pockets that might exist.
'99 black 986
Old 11-01-2013, 06:13 AM   #6
jaykay's Avatar
Thanks yes, I wish I owned the tool! Do you think it is safe to let it settle on its own?
986 00S
Old 11-01-2013, 09:05 AM   #7
If you follow the burping procedure you should be ok. Watch for dropping coolant levels and especially watch for any sign of overheating. Tell Santa you want a Uview Airlift for Christmas. Don't let him feed you any crap about shooting your eye out!
'99 black 986
