Performance and Technical Chat
Water Pump Change - coolant loss
10-31-2013, 07:05 AM
jaykay
Just changed my water pump and had a vacum fill. I have had to add 1.5 L of premix since after driving for a total of two hours
Is this normal or do I have a problem!!
986 00S
10-31-2013, 07:26 AM
2
Flavor 987S
Normal. It's burping.
10-31-2013, 08:01 AM
3
jaykay
Thanks for your feedback!
I had assumed that the pressure fill would limit the top up to 0.5 L or so.......live and learn
986 00S
10-31-2013, 04:17 PM
4
pjq
yes a good vacum fill should have eliminated that problem.
A good burp is ok but now monitor your coolant level and temp.
11-01-2013, 06:42 AM
5
Mark_T
After filling your system, you can then use the Uview tool to pull vacuum again to draw out any remaining air pockets that might exist.
'99 black 986
11-01-2013, 07:13 AM
6
jaykay
Thanks yes, I wish I owned the tool! Do you think it is safe to let it settle on its own?
986 00S
11-01-2013, 10:05 AM
7
Mark_T
If you follow the burping procedure you should be ok. Watch for dropping coolant levels and especially watch for any sign of overheating. Tell Santa you want a Uview Airlift for Christmas. Don't let him feed you any crap about shooting your eye out!
'99 black 986
Hybrid Mode
Switch to Threaded Mode
03:26 AM
