Old 10-25-2013, 07:24 PM   #1
1999 base
Meir's Avatar
steering rack
hello guys.
i'm back, and i need your help.
my friend that i sold my car to, came over last night for a drink, and told me that he thinks he is missing some steering fluid, since he can hear the pump making noises when turning the the car.
we took it for a spin, and noticed the noise only on left turns. we drove the car back to my garage thinking to add some fluid and get it done. since he also needed an oil change, i offered him to take my car, and pick his ca tomorrow,after ill get it done. (after all he came for some drinks )
so i put the car on the lift and opened some bears.
today, when i got back from work, i found a puddle of steering fluid on the front passenger side.
so what are my options?
a new rack is around 1K.
refurbished is 350-450. i can get one from ebay for 150-250.
beside the leak, the steering functions well.
is there a way for me to rebuild it myself?
the parts diagram shows a $4 sealing ring that goes on the rack (part 4).
is that simple as that? or there is more to it?
gonna do some reading on the Bentley book and the 101, but will appreciate any advice
thanks.
Meir
Old 10-26-2013, 10:14 AM   #2
Jager's Avatar
Meir,
As talented as you are I would attempt replacing the seal. I suspect you are in fairly uncharted waters here because I do not recall seeing an issue like this on the forum nor have I come across this problem (knock on wood) and I have over 254,000 miles on my Boxster.
Jäger
300K Mile Club
Old 10-26-2013, 10:22 AM   #3
Jager's Avatar
Meir,
I used this to remove the ends:
Harbor Freight has them, or the full kit, at reasonable prices.
Jäger
300K Mile Club
Old 10-29-2013, 01:29 PM   #4
1999 base
Meir's Avatar
Hi Jager. thanks for the reply.
you might be right.
i found some DIY for almost any other Porsche out there except for the 986/996
the frustrating part is, that the steering rack is perfectly good (Except for the leak) and it looks like the seal can be access pretty easy:
it also looks like the steering rack on the car was replaced before. see the marks on it:
i already called Vertex on Saturday morning, and i can pick up a refurbished rack for around $400. by the time i got the part of the car (for core exchange), they were already closed, so i will have to go there this weekend.
was thinking since i have the time, maybe i should give it a try, and fix it.
the problem is, i was reading the parts diagram wrong.
part number 4 is a rubber ring that seats externally on the rack.
cannot fined the required seals for the rebuild, anywhere.
its a little bit strange that no one ever rebuild this thing as a DIY.
i found a lot of posts for rack replacement with new/used/refurbish ones, so the issue defensively exist.
anyway, i'm going to mess with it over the week, and this Saturday will replace it with a refurbished one. unless someone will chime in with a fix
and by the way, i got this tool also from HB. works great.
Old 10-30-2013, 08:01 PM   #5
Porsche "Purist"
Paul's Avatar
Make sure the system has the correct fluid before replacing the rack. If your car has the wrong fluid the new rack will soon leak.
1987 924S. 2002 996TT. PST-2
Old 10-30-2013, 08:04 PM   #6
Porsche "Purist"
Paul's Avatar
Meir,
I just remove the nut and hammer the side of the arm, usually they pop right out.
Old 04-06-2023, 10:20 PM   #7
Hey Meir,
Was there any progress on this, I've got the same issue with mine & finding it difficult to find a seal kit.
http://i13.tinypic.com/49ied5h.jpg
2000 2.7 Boxster
aussieboxy is offline   Reply With Quote
Old 04-07-2023, 05:22 AM   #8
1999 base
Meir's Avatar
Originally Posted by aussieboxy View Post
Hey Meir,
I ended up getting a rebuild rack from Vertex.
