Old 10-03-2013, 12:29 PM   #1
irregular idle
My idle just stared to be surging last nite for the first time. The only thing that has changed was I installed a battery cut off switch. Which of course meant, the negative cable was off for a few minutes.
gsmith329 is offline   Reply With Quote
Old 10-03-2013, 12:52 PM   #2
Heiko's Avatar
Run the throttle Body Adaptation proceedure...
If that doesnt do it, clean your throttle Body and also get a can of Mass Airflow sensor cleaner and clean it good... then give it a shake and let it dry. It's alcohol based so it dries quick!
That should do the trick unless you have a vac leak or defective MAF sensor.
H
Previously owned:
Old 10-06-2013, 09:51 AM   #3
irregular idle
wow after two car cruise ins (wed n sat) idle became regular again. And one little street race shifting at 6500 through 3 gears
Old 10-06-2013, 08:34 PM   #4
steved0x's Avatar
Is this where you put the key in, turn it to the right for a minute and then take it out, and then put it back in?
