Thread: irregular idle
Old 10-03-2013, 12:52 PM   #2
Heiko
Heiko's Avatar
Run the throttle Body Adaptation proceedure...
If that doesnt do it, clean your throttle Body and also get a can of Mass Airflow sensor cleaner and clean it good... then give it a shake and let it dry. It's alcohol based so it dries quick!
That should do the trick unless you have a vac leak or defective MAF sensor.
H
Previously owned:
