Old 09-08-2013, 07:22 PM   #1
2006 987
986_inquiry's Avatar
looking for xenon HID foglights to match OEM xenon hid headlights in 987
looking for xenon HID foglights to match the bright white OEM xenon hid headlights in 987, anyone know of a kit or ebay or something? Been searching everywhere, planet-9 had a few posts but they were all cayman and I think the cayman has different foglights than the 987
avoiding LED, went that route on 986 foglights and they were very dim
EDIT: there's a good chance i have my bulb terminology incorrect. Please forgive me, i hope it still makes sense what i'm looking for
2006 987 2.7 manual silver/black, PASM, OEM drilled rotors, heated seats
1998 986 2.5 manual black/tan with bad engine = SOLD
986_inquiry is offline   Reply With Quote
Old 09-08-2013, 11:44 PM   #2
Nine8Six's Avatar
Might want to try the HIDplanet.com forum instead. These guys specialize in car lighting and would be able to help you out finding what you are looking for.
Best of luck mate
Old 09-09-2013, 03:56 PM   #3
Below is the response I got today from TRS. I placed the order this afternoon. I've completed two conversions on E46 headlights using FX-R projectors, and it was very difficult to get the alignment set perfectly.
These projectors thread right into the H7 socket, making it an install. I added the adhesive to reseal the lens, for an additional $10.
The Mini H1 projectors definitely are an easy install in the Boxster / 996. The stock H7 socket in the reflector is large enough for the projector to install through and then tighten down with the included hardware.
Bi-Xenon Morimoto Mini H1 Stage III Kit: Bi-xenon Morimoto Mini Stage III Kit (H1) - Complete Retrofit Kits from The Retrofit Source Inc
Mini H1 6.0 Bi-xenon projectors (LHD)
Morimoto 3Five Ballasts
Morimoto 3Five Bulbs
H7 Canbus Harnesses
High Beam Splitters (by request)
Bi-Xenon Monograms (by request)
Standard Mini Gatling Gun shrouds (or you can upgrade to the Iris or any other for an additional $25)
Optional LED rings (that mount to the shrouds)
Comes out to $270 shipped free here in the US.
MitchSF is offline   Reply With Quote
Old 09-10-2013, 01:45 PM   #4
2006 987
This is for a 987 boxster, correct? Not the first generation 1997-2004 986 boxster?
Thanks! i think this is what I was looking for
which bulb brightness matches the factory lights?
Old 09-10-2013, 02:44 PM   #5
Nine8Six's Avatar
6,000k running off a 35watts ballast. Pure white and safe.
You can go up to 55watts if blinding others isn't an issue with you. Also, the 55 watts runs really hot so make sure you buy from a reputable manufacturer (carry a fire extinguisher also).
hope this helps a bit
Old 09-10-2013, 03:31 PM   #6
woodsman's Avatar
You'll want 4300k if you still have the factory HID bulbs. 6000k looks bluish in comparison.
Old 09-10-2013, 03:43 PM   #7
Nine8Six's Avatar
So I'm guessing the factory is yellowish.
Some says pure white is 4300k and others says 5k. Not 6k my bad
Old 09-10-2013, 04:37 PM   #8
Mine is a 986. I ordered the kit with 5000K bulbs. Light output is slightly less than the 4300K factory temperature, but not really noticeable.
To clarify, the base of the projector is threaded. It goes through the hole in the lens assembly where the H7 bulb was mounted. From what I've read, minor work needs to be done with a Dremel so the projector will sit flat in the hole, then a nut is tightened on the threads to hold the projector in place. This is nothing compared to the work needed to mount FX or similar OEM projectors.
Think I changed the topic from fogs to headlights, inadvertently. Sorry!
Old 10-24-2013, 07:52 AM   #9
2006 987
I do not think the 987 foglights are H7. According to this article they're H8 35W
What kind of bulb is the small bulb in Boxster foglight assembly? -
I believe H7 are the headlights
Old 10-24-2013, 08:03 AM   #10
2006 987
here's a good article for a cayman
Exterior Light Makeover - Part 1 - Articles
apparently Hoen makes some bulbs that match called xenonmatch designed specifically to match factory HID low beams
Hoen
They're $30 a pair, not an unreasonable price for a decent pair of bulbs.
I ordered some, I'll get some photos up when they arrive
