Old 10-16-2013, 04:16 PM   #21
Just a Swede
Thumbs up
And RoboTop will resume shipping worldwide.
Thats Realy good to hear!
What happens if you need to put top in service mode?
Press the button again and the top will stop.
smygolf is offline   Reply With Quote
Old 10-16-2013, 06:07 PM   #22
i think i had the original robotop when it first came out. but there was a problem with the light. the switch no longer illuminated underneath with the relay in place. has that been fixed? if so, i am interested again. is there a discount for forum members? no biggie if not..just curious.
-Tuan
tuanle16@juno.com
tuanle16 is offline   Reply With Quote
Old 10-16-2013, 11:38 PM   #23
Guvs's Avatar
Funny you should be asking that.
My exact thoughts as well, thstone what do you think ?
Guvs.
I could be your UK Rep. lol !!
Guvs is offline   Reply With Quote
Old 10-19-2013, 09:41 AM   #24
KevinH1990's Avatar
According to the robotop web site, the backlight of the button will not work.
Robo-Top, One-Touch Convertible Top Module for 996 Cabriolets and 986 Boxsters, Convertible top module for Boxster and 911 Carrera
Although it seems like that would be relatively simple to address, it might be that the circuit for the backlight is being used for another function.
Old 10-22-2013, 01:46 PM   #25
I made a top opener using an Arduino board. I haven't posted about it since I installed it in May because I wanted to be sure it was reliable first.
It mimics the way the power windows work:
short tap on open or close will fully auto-open/close the top (less than .5 second tap), another tap or long press of either open or close will stop the current auto-open/close function. Holding on open or close will manually open or close the top for as long as you hold it.
the only annoying thing is that it needs a switched +12v supply...I just spliced into the stereo's switched +12v (not the +12v switched by the stereo being on, the +12v from the ignition being on).
Arduino nano:$10
transistors, resistor, and 5v regulator:$10 -$15 (had all parts laying around)
Fun/simple Saturday geek-out project:$priceless
Polaris is offline   Reply With Quote
Old 10-23-2013, 03:00 PM   #26
2006 987
986_inquiry's Avatar
Arduino nano:$10
very nice! Where do you buy your Arduino boards?
Also the 987 solved this: from 6mph to ~35mph the roof is automatic one touch. Under 6mph and you have to hold the switch.
2006 987 2.7 manual silver/black, PASM, OEM drilled rotors, heated seats
1998 986 2.5 manual black/tan with bad engine = SOLD
986_inquiry is offline   Reply With Quote
Old 02-19-2016, 03:56 AM   #27
mikesz's Avatar
I did this mod. works great. I bought a spare so I can always change back if I need to.
99 Porsche Boxster
