Old 08-29-2013, 02:41 PM   #2
Steve Tinker's Avatar
Did you inspect the coil packs when you removed them to access the plugs?
Look for small cracks and corrosion - once moisture penetrates the electrical windings of the coil packs, the voltage tracks to ground causing the missfire.....
2001 MV Agusta F4.
