Originally Posted by Steve Tinker
Did you inspect the coil packs when you removed them to access the plugs?
Look for small cracks and corrosion - once moisture penetrates the electrical windings of the coil packs, the voltage tracks to ground causing the missfire.....
I swapped plugs with other cylinders that were working and also the Coil Packs as well.
