Old 08-20-2013, 11:56 AM   #1
Spyderman's Avatar
Eternal IMS Fix
Any thoughts regarding this latest innovation/solution to the Intermediate Shaft (IMS) failure problem?
News | EPS
The roller bearings in lieu of spherical bearings would provide increased load bearing and contact surface area for the shaft. Not sure how this arrangment is lubricated, but assume oil splash within the engine case?
Spyderman is offline   Reply With Quote
Old 08-20-2013, 12:56 PM   #2
News | EPS
Old news, yet another copy cat with a different style steel bearing trying to cash in. More interesting is that most of the rest of that website is bogus text.....
Old 08-20-2013, 02:57 PM   #3
Anyone else have trouble with the other tabs on that web site?
Ask them how many they have tested and how long they have run before using any new IMS approach. Not saying they can't be better, just compare the experience they will claim with that of the other longer available approaches. You know that thousands of real world experiences has to give you a better feel than a few test cases run for a few months.
Time will tell.
Old 08-20-2013, 03:48 PM   #4
Johnny Danger's Avatar
Eternal or external fix ?
Old 08-21-2013, 03:26 AM   #5
Not a good idea!!! Cylindrical roller bearing cannot tolerate any misalignment, such as due to manufacture or shaft deflections. If they had gone to a spherical roller bearing it would be a better option as its self aligning, but unfortunately they are not available in the correct dimensions.
howe is offline   Reply With Quote
Old 10-20-2013, 10:20 AM   #6
I am copying over my 2 cents on this from Rennlist:
I saw the ad for the Eternal IMS fix also and this got me to looking at what people were saying about it and the other fixes. I have not weighed in on this topic much, until the last few days. I thought I'd weigh in on this one too.
Frankly the Eternal IMS fix from Vertex scares me. No data, no information to really back up their product, not a word.
1. The roller bearing is traditionally great for radial loads but bearing manufacturers rate it as "unsuitable" for thrust loads. Vertex calls it a "thrust" roller bearing but does not explain (again no technical detail) how it handles thrust loads. The bearing at the other end of the IMS was not made to handle thrust loads. The stock ball bearing that is so much trouble was indeed made to handle thrust loads. So the stock bearing is weak when it comes to radial loads, but probably sufficient for the limited axial loads you would see. The Eternal IMS addresses the one issue - radial loads, but fails to provide a means to handle the axial loads.
2. This is a steel bearing with even greater contact area than a ball bearing, but still with marginal, at best, lubrication. This bearing needs MORE lubrication than the stock bearing and a lot more than the ceramic ball bearing. The fact that no provision is given for additional lubrication likewise scares me.
I don't think this is a viable option... best to look at the other ball bearing options, direct oil feed, or plain bearing. Now IF there was a provision to handle thrust and a direct oil feed was added, then this might be a very nice solution. Without those two issues addressed though I would not dare put this product in either of my cars needing an IMS fix.
Kirk Bristol
2000 Boxster S - Gemballa body kit, GT3 front bumper, JRZ coilovers, lower stress bars
2003 911 Carrera 4S - TechArt body kit, TechArt coilovers, HRE wheels
1986 911 Carrera Targa - 3.2L, Euro pistons, 964 cams, steel slant nose widebody
1975 911S Targa - undergoing a full restoration and engine rebuild
Also In The Garage - '66 912, '69 912, '72 914 Chalon wide body, '73 914
Kirk is offline   Reply With Quote
