Old 08-10-2013, 11:46 PM   #1
I have a Porsche Boxster 2.5 and it has failed the emission test on to high Co. The car has been serviced including fuel filter, plugs, oil, air filter, oil filter and coil packs. In addition to this its had new Cats, new o2 senors and I have cleaned the Air flow mass sensor. There are no error codes coming up, have you any idea why the ecu is providing to much fuel so its pushing up the Co emissions? I have cleaned the air system and I have mixed the petrol with injector cleaner, could this cleaner affect the readings? Please can you help? Thank you
charles-007 is offline   Reply With Quote
Old 08-12-2013, 08:03 AM   #2
Just in case the injector cleaner loosened up a good amount of carbon deposits, you may wish to try an Italian tune-up on the highway and then take it back in.
southernstar is offline   Reply With Quote
Old 08-12-2013, 11:58 AM   #3
Thanks for that but I have tried that and still no joy.
Old 05-10-2017, 10:29 AM   #4
Charles,
Did you ever get any further forward with this query , mine is doing the same
Rob
Jeff8529 is offline   Reply With Quote
Old 05-15-2017, 12:00 AM   #5
geraintthomas's Avatar
Check the throttle body and plenum jubilee clips. I had mine fail an MOT only to find that a pipe was loose causing way too much air in the system. Tightened it up and it flew passed the MOT.
Porsche Boxster S Type 986
Bi-xenon Headlight Upgrade | 987 S 18" Anthracite Alloys | Android Head Unit | 5000k 55w HID's | 5000k Cree DRL's | 5000k Cree number plate lights | Cree LED Indicators | One-touch roof operation | Bypass exhaust pipes | Parking sensors | Ambient footwell lighting
geraintthomas is offline   Reply With Quote
