Old 06-03-2013, 04:28 AM   #1
OIL LEAK :mad:
I changed my springs yesterday and I found an oil leak under the engine where the gearbox mounts to the block. How worried shall I be .
I know about the IMS but how long would you say I roughly have.
Also Ive been looking at replacing it with the clutch and I know there is a dual mass flywheel and single, how do I find out without doing the obvious. (taking it apart) I have.
GemballaPhil is offline   Reply With Quote
Old 06-03-2013, 05:10 AM   #2
Recent:
http://986forum.com/forums/general-discussions/45963-2003-boxster-s-oil-leak-after-winter-storage.html
Old 06-06-2013, 03:05 AM   #3
Nimbus117's Avatar
The IMS bearing can fail without warning, especially if you have the later single row bearing. You should be concerned if this is a single row bearing. Is there oil on the floor in the morning?
Where are you based? There is an excellent specialist who will replace your clutch, IMS bearing and RMS for £1500 called Revolution Porsche. Have a look on Boxa.net
Forgot to ask what year and model Boxster you have.
2003 Boxster 2.7L
2010 Civic Type R
Old 06-06-2013, 11:56 AM   #4
The quandry that this symptom presents is trying to decide if its an IMS leak or a RMS leak. An IMS leak is worrisome while an RMS leak generally isn't serious.
First, be SURE that the leak is coming from between the transmission and the engine. My car had a similar leak and even the dealer said that it was either IMS or RMS but the leak disappeared when I replaced the spark plug tubes.
Otherwise, the only way to know what is leaking is to remove the transmission.
Old 06-06-2013, 06:18 PM   #5
San Diego Boxster
drbodzin's Avatar
Check this thread.
Oil Leak - Pulling Trans to change RMS, IMS, Clutch, etc
Happy Boxstering!
Miles
1998 Black Boxster (owned since 2001)
drbodzin is offline   Reply With Quote
