Old 05-29-2013, 10:11 PM   #1
6 speed transmission repair question
It seems that the pinion bearing on my 6 speed tranny is failing (the differential has excessive noise when you unload it at low speed).
A friend that specializes on Porsche cars told me that you need a press with 40,000lbs capacity to replace the bearing...
I am planning to remove the pinion shaft, by any chance do you know where can I take it to get this bearing replaced?
PS; I live in the LA area
Old 05-30-2013, 02:56 AM   #2
The pinion bearing is the last thing on the counter/output shaft. It will require everything pressed off the shaft in order to get to the bearing.
Try Callas Rennsport. There is a special plate that holds the shaft centered and vertical for pressing. I am sure someone could rig up a device, but the special tool is really nice to have when pressing everything back on.
Skoot
Skootnasty is offline   Reply With Quote
Old 05-31-2013, 12:16 PM   #3
Skoot
Thanks for the tip Skoot, Tony Callas told me that Jeff Ericson (AASE) had the special tooling, but Jeff instead send me to California Motorsports (AZ)
California Motorsports - Porsche transmissions, transaxles, gears, differentials, parts, service, manufacturing
It seems that you need a 40 ton (..!) press to remove the pinion bearing, most likely I will be sending the entire output shaft to CMS..
Regards, Gilles
Old 05-31-2013, 12:38 PM   #4
BYprodriver's Avatar
Regards, Gilles
Gilles CMS is good, I love how my trans shifts with their billet shift arrester. You should have one installed while your trans is apart.
Hergesheimer Motorsports is good with trans too & they are in Lake Forest, talk to Eric there.
Cayman take off parts here: http://www.ebay.com/itm/01X-409-121-A-498-081-Porsche-987-Cayman-S-Boxster-Differential-Pinion-Set-/170941052728?pt=Motors_Car_Truck_Parts_Accessories&hash=item27cce17738#viTabs_0
Old 05-31-2013, 04:31 PM   #5
[QUOTE=BYprodriver;345268]Gilles CMS is good, I love how my trans shifts with their billet shift arrester. You should have one installed while your trans is apart.
Hi Bill,
Yes I know Eric and Mark (actually they are very close to my office) and you are right they have a great shop, but was not aware that they also rebuilt gearboxes..
However I do know that Eric goes through a lot of them on his race car... ha
