Old 05-21-2013, 10:21 AM   #3
Most of this can be related to the P0501 code; that indicates the car has no wheel speed signal, which it gets from the left rear wheel speed sensor. Could be the sensor, the sensor could be jammed up with brake dust (common) a break in the wiring harness, or the AMS module. It concerns me that the Durametric cannot see the ABS module.
The left rear wheel speed sensor can be tested with a multimeter, look for 1.6 to 1.8K ohms across pins 1 & 2 at the sensor. If the Durametric could see the ABS module, you could read the sensor values using it, but that is obviously not possible.
You can also look for a shop with a Baum iScan tool which often can read the ABS system when a Durametric cannot.
Awesome, thank you, will get the multimeter out tomorrow and report back!
monty77uk is offline   Reply With Quote
