CEL / ABS / Brake pad warning light
Hi all,
Just bought my 2nd Boxster .. budget limited due to house renovations so I picked up a late 2003 986 3.2S with just shy of 140k miles on the clock.
History was plentiful and expensive and it is in generally very good condition so I took a punt.
I have the following issues:
ABS/Brake pad wear lights permanently lit
- Pads are fine, replaced all 4 sensors, still lit
- Durametric wont connect to ABS module
CEL .. this is new, only came on last night.
Found the following codes with Durametric:
Motronic 7.8
Current Fault Codes
P0501
Factory Fault Code 120 - Vehicle speed
Open circuit
P2096
Signal delay time for oxygen sensor ageing
Above limit
..the first one, could that be related to the ABS?
2nd one - knackered post-cat o2?
Thanks!
Adam
