04-30-2013, 10:05 PM
#1
unidentified small rubber hose
While replacing my motor mount I found a small rubber hose. It was dangling close to the motor mount, wasn't connected to anything and had already been mangled by the serpentine band a bit.
I think the other end is coming from the frunk, see first photo, it isn't connected there either.
It runs underneath the car together with three other small tubes, see second photo.
For the time being I've secured it with cable ties.
Any one knows what this small rubber hose is for?
05-01-2013, 09:59 AM
#2
Is it the overflow tube for your coolant tank?
'99 black 986
05-01-2013, 10:52 PM
#3
Yes, could be that it fell off. But why is it ending up in the frunk?
Thanks.
05-02-2013, 06:12 AM
#4
I think it attaches to the engine side of the coolant tube manifold and just hangs down from there and is held in place by one or two clips. It's been a few months since I did the coolant tank job so my memory of how it all goes is a bit fuzzy.
'99 black 986
05-02-2013, 09:56 AM
#5
vent hose for battery?
05-02-2013, 10:39 AM
#6
I didn't notice that you said it came from the frunk, I just saw the bit about it hanging near the motor mount. Definitely not from the coolant tank then. Sorry, I have no idea what that hose would be.
'99 black 986
05-03-2013, 02:18 PM
#7
Opposed to Subie Burble
That to me looks thicker than the overflow hose for the battery, spendy, but it was my first thought too when he mentioned the frunk...but then I wondered why the heck it was ending up all the way back by the engine when that's supposed to run down to the front wheel well. So I guess that's not it. I'm at a loss here, nieuwhzn. Is your coolant overflow hose running down ahead of the right rear wheel well like it's supposed to?
-O/D
IMSR + RMS
Robbins glass window top
05-03-2013, 10:52 PM
#8
No idea. I'll have a look this weekend when I jack up the car to remove the secondary cats.
05-04-2013, 04:51 PM
#9
That is the overflow drain hose for the coolant expansion tank.
05-08-2013, 03:30 PM
#10
So does that mean the whole hose is just sitting there in the frunk? Or is the hose actually running from the tank up to the frunk? Neither makes sense, but if it's disconnected from the tank, you'll definitely want to get it reconnected so any overflowing coolant doesn't just drain out into the trunk, engine bay, or cabin, and instead goes down by the right rear wheel like it's supposed to.
-O/D
IMSR + RMS
05-08-2013, 10:30 PM
#11
I'm as puzzled as you are.
What is the best access to the point where the overflow of the coolant tank is located? Just to check is there is a hose connected there.
05-09-2013, 06:19 AM
#12
The overflow tube attaches to the engine bay side of the coolant tank manifold and hangs down. There should be a couple of clips securing it to another line to hold it in place, although the clips may be gone. You'll need to get under the car by the right rear wheel and peer up with a flashlight to see if it is there.
'99 black 986
05-10-2013, 11:00 PM
#13
Thanks! Jacking up th e car again. Tempted to get a car lift.
05-11-2013, 05:20 AM
#14
Homeboy981
When you over flow the gas on fillups…have you noticed the smell in your frunk?
It could be a gas overflow line - just a guess but it would be worth pouring a little gas down there and MAKING SURE it is not a fuel line. My $.02 - remember you got what you paid for!
