04-11-2014, 08:24 AM
#41
I was chatting with the good folks at ECSTuning.com and they mentioned that H&R has a wheel Stud kit. I haven't purchased yet, but it is a bit cheaper than the kit listed below.
http://www.ecstuning.com/ES2730962/
http://www.ecstuning.com/ES240/
I'll do a bit more research and see if I can find any more info out...
Mantis 2.0L Deep Sump, de-snorkeled, Bilstein PSS9 Coil-Overs, Rennline lug studs, and auto crossed regularly.
04-11-2014, 08:41 AM
#42
Update: Spoke to the guys at H&R - very helpful. Here is a link to the kit:
H&R Introduces Quick-SafeŽ Bolt-Stud Conversion Sets | Press || H&R Special Springs, LP
They just need to know what length stud that is needed. I think 50mm would be about right - anyone confirm for a stock wheel setup?
04-11-2014, 10:56 AM
#43
If anyone needs to remove their locking nuts without a key.
I have the tool if you'd like to buy it at a 50% discount ~$17.
I only needed to use it one time x4 bolts to remove my Lockers when the previous owner could not find the key for me.
I comes with 2 remover sockets for different type lockers, and a short bar to tap the locker out of the socket after its removed.
CIMG3470 - YouTube
"It broke because it wants to be Upgraded  "
04-14-2014, 09:59 AM
#44
Originally Posted by Dlirium
The stuff I posted may not actually work. While ECS said these woudl work, I called H&R - They claimsthat the lug nuts are for VW and Audi, and will NOT work with Porsche. They do not make a Porsche compatible lug nut.
I went to Rennline and found exactly want I needed:
Competition Wheel Stud Conversion Kit-Rennline, Inc.
Great kit, comes with nuts and studs, and made for a Boxster. I ordered and will install likely next weekend!!
| Thread Tools |
| Display Modes |
Linear Mode
