Old 02-27-2013, 08:36 AM   #1
Solved difficult shifting problem
Hi everyone,
Just wanted to share how I repaired a shifting problem in my '02 Boxster S. For a while I had an intermittent problem shifting into reverse, I had to move the shifter to the neutral position in between 5th and 6th and then put it in reverse. This would happen about once a week, then it became every day.
After jacking up the car and placing it on jack stands I crawled underneath and had my son move the shifter through all the gears.
I found out that the cable had popped out of the bracket because of a worn clip. after bending the clip back in shape the shifting was once again smooth.
I'm going to replace the clip, I just hope they will sell it without the cable assembly
2002 Boxster S
Artic silver
6 speed
troop1 is offline   Reply With Quote
