Old 02-27-2013, 07:36 AM   #1
Solved difficult shifting problem
Hi everyone,
Just wanted to share how I repaired a shifting problem in my '02 Boxster S. For a while I had an intermittent problem shifting into reverse, I had to move the shifter to the neutral position in between 5th and 6th and then put it in reverse. This would happen about once a week, then it became every day.
After jacking up the car and placing it on jack stands I crawled underneath and had my son move the shifter through all the gears.
I found out that the cable had popped out of the bracket because of a worn clip. after bending the clip back in shape the shifting was once again smooth.
I'm going to replace the clip, I just hope they will sell it without the cable assembly
2002 Boxster S
Artic silver
6 speed
troop1 is offline   Reply With Quote
Old 02-27-2013, 07:41 AM   #2
Homeboy981
Homeboy981's Avatar
Hey @Troop1,
Let me know IF you find JUST THE CLIP! We need a few here too but have been unsuccessful finding them without the darn cable attached!
Drive Happy!
Old 02-27-2013, 08:35 AM   #3
Auto Atlanta or Pelican "JUST THE CLIP" have what you want I think, part 986 424 490 00.
derfo is offline   Reply With Quote
Old 02-27-2013, 11:02 AM   #4
Originally Posted by troop1 View Post
Hi everyone,
6 speed
Troop1,
You may also want to use a plastic zip tie to secure the cable to the metal clip
Old 02-27-2013, 12:29 PM   #5
Thanks for the info
Old 02-27-2013, 02:29 PM   #6
Joe B's Avatar
No wonder mine already had 2 zip-ties on top of the clip when I bought the car .
Old 03-01-2013, 03:26 PM   #7
Hi everyone,
I found the clip Its part #986 424 049 01 $39 at dealer.
Thanks for the help guys
'02 Boxster S
Artic silver
6 speed
Old 03-08-2013, 09:29 AM   #8
1997 Porsche Boxster, problem with triptronic transmission
it's stuck in 4th gear. Any suggestions?
Neil is offline   Reply With Quote
