02-22-2013, 02:05 AM
Rear Spoiler
Hi, my rear spoiler does not operate at speed. It works fine with the manual switch both up and down, when left up from the switch it retracts when stopped.
I have swapped the relays in the rear compartment with no change to the problem.
Anybody any ideas where I start to look?
As it is speed controlled, what gives the signal to the motor to extend? Is this a different circuit that the manual switch?
Simon
2002 2.7 base
02-22-2013, 06:40 AM
how do you know or sure it doesnt go up at 75 mph? ive always wondered if mine actually goes up, as there is no dash light to show it is, and you cant see it in the rear view mirror
02-22-2013, 07:18 AM
Carefully drive along side a semi that 's pulling a trailer that you can see a reflection of your vehicle in.
02-22-2013, 07:23 AM
Fantastic! I always wondered the best/safest way of doing this. LOL (not everyone has "Danger" in their names)
2000 Boxster S
02-22-2013, 07:25 AM
I just recently drove from NC to FL and back, and when the sun was not overhead I could see my shadow and for the first time I could see if the spoiler was up or down. It was up most of the way
02-22-2013, 07:28 AM
Well, I actually don't know if my spoiler goes up either. Time to put the camera facing rear.
(What I'd like is to remove the oem retractable spoiler and put an aftermarket spoiler - some low profile that does not destroy the design intent of the car)
2000 Boxster S
02-22-2013, 08:00 AM
This can help if your spoiler isn't going up !
02-22-2013, 08:12 AM
LLLOOOOLLL!!!
The resourcefulness here is amazing. Problem completely solved.
Step 1 - Use the last suggestion to make sure it goes up
Step 2 - Drive alongside a semi and look for the reflection
2000 Boxster S
02-22-2013, 08:17 AM
Passenger looked out of the back
Simon
02-22-2013, 10:20 AM
LLLOOOOLLL!!!
Wish I hadn't read this at work. People are staring wondering what the heck I think is so funny. Good thing I didn't have a mouthful of coffee...
'99 black 986
02-25-2013, 08:24 PM
E3E
Have someone in another vehicle follow you?? lol
98 White - Totalled
94 Honda Accord Coupe
02-26-2013, 04:35 AM
I'm only 5'11" and I can see mine whhile driving if I push myself upward in my seat and glance quickly over my shoulder. It's not that big of a deal...I just use an empty stretch of straight road.
I;m not advocating this method; mearily suggesting that it's possible.
02-26-2013, 06:20 AM
Should we call an Authorized Porsche dealer if our spoiler stays up for more than 4 hours???
Seal Grey
02-27-2013, 09:08 AM
Ah well - ask a silly question........
02-27-2013, 01:00 PM
1999 base
not silly at all.
the two relays are activated by the cluster .
however, the cluster detects the position of the spoiler via a small switch located on the spoiler rail.
you will have to remove the mechanism cover to get to it.
this is the diagram just in case (for 2000-2004 cars)
02-27-2013, 01:05 PM
1999 base
by the way, if one wants, he can use the wires connected to the switch to activate a LED to show the status of the spoiler.
gray/green and gray/brown.
02-27-2013, 01:34 PM
Your spoiler warning light (dash cluster) should come on if it is not operating correctly. I am unsure of the exact inputs and reliability for the light but they would likely be things like speed signal and the spoiler track micro switch state....
...drop two special purple pills into a full tank of gas and your spoiler should stay up all week end
986 00S
02-27-2013, 08:17 PM
Special Purple Pills ?? That is Nexium for acid reflux. Will it stop oil from dripping out of the RMS ?
2000 Boxster S
