Old 02-11-2013, 10:51 AM   #1
Rob Vine
Robsducati's Avatar
Wheel spacers
Does anybody have wheel spacers fitted?
After looking at a couple of pictures of members cars, I quite like the wider look.
I was thinking 20mm rear, 15mm front.
Are there any noticeable handling compromises?
Do they put to much stress on wheel bearings?
What is the max width of spacer you can get away with?
Rob Vine
2004 Boxster S
Ducati 749S
1993 928GTS sold
Robsducati is offline   Reply With Quote
Old 02-11-2013, 01:15 PM   #2
If you don't track your car then those sizes you mentioned should be fine.
SF-Rockster is offline   Reply With Quote
Old 02-11-2013, 02:14 PM   #3
Allen K. Littlefield's Avatar
I have 15mm front and back. Same sized wheels just out 15mm more. They do not protrude from the wheel wells and I have no rubbing issues with 17" stock Boxster wheels. Have yet to have any suspension problems with this set up. I also have M030 Sway bars front and rear. Handles real well with no lean on hard corners. They do tend to throw up a bit more road grime onto the rocker panels and rear fenders.
AKL
Old 04-01-2013, 05:22 PM   #4
Newb
V-Rod's Avatar
AKL
Allen,
Do you have any pictures of your boxster with 15mm spacers and stock 17's all around? Do you have the stock or ROW M030 suspension?
1999 Boxster Ocean Blue Metallic/Savannah Beige
2001 Harley Davidson Road King w/Ultra Kit Black/Chrome
2004 Jaguar XJ8 Seafrost Metallic Green/Sand
2008 Land Rover LR3 Alaska White/Alpaca
2012 Honda Odyssey Touring Dk Grey/Lt Grey
V-Rod is offline   Reply With Quote
Old 02-11-2013, 05:51 PM   #5
LAP1DOUG's Avatar
Make sure that you get hub-centric wheel spacers which have a lip in the center that supports the wheel, and that you get longer wheel bolts to match the thickness of spacer that you use. I have been tracking with Porsches and BMW's for years with hub-centric spacers with no issues. Your wheel bearings may wear a little faster, but big deal - they are made to be replaced.
By the way, Brey-Krause just announced a new line of all hubcentric spacers (even the thinner ones):
R-5010 Hub-Centric Wheel Spacers
The weird thing is that their web site advertises them only for 911's. Does anybody know if these will these fit a 986?
Kippis
986S
991S
Van Diemen RF97
Old 02-13-2013, 12:04 AM   #6
Rob Vine
Robsducati's Avatar
Thanks for the advice. I will go with the 15mm fronts and 20mm rears and make sure that at get the hub centric spacers with the longer bolts to suit.
Will post some pictures when all is complete.
Rob Vine
2004 Boxster S
Ducati 749S
1993 928GTS sold
Old 02-13-2013, 04:16 AM   #7
Johnny Danger's Avatar
Horrible design if you ask me !
Old 02-13-2013, 12:59 PM   #8
Bfan's Avatar
JD why do you think they are so horrible. They look quet smart to me, I think they will do the job of centring the wheel, even on a thin spacer with this design
Bfan is offline   Reply With Quote
Old 02-13-2013, 04:16 PM   #9
They're not bolt centric, nor does it appear as though they countersink to the hub.
Old 02-13-2013, 05:23 PM   #10
Moderator
+1, Looks concerning.
Old 03-25-2013, 06:01 PM   #11
JD, can you post up a link to some spacers that you recommend?
ohhh my is offline   Reply With Quote
Old 03-25-2013, 06:29 PM   #12
There are numerous sources from which you can purchase high quality spacers from. The important thing is to make sure that they are of the correct design. Here's an example of a properly designed spacer.
- hubcentric
- correct bolt pattern
- machined countersink tap
Old 04-01-2013, 05:32 PM   #13
Newb
V-Rod's Avatar
I am having my suspension updated to the row m030 next week and like the look of a wider stance but do not want to effect accelerated wear on tires, bearings or components. what is the recommended set of spacers. JD?
Old 04-01-2013, 05:44 PM   #14
Given the proper application, accelerated wear on tires, bearing and or other components caused by spacers is a myth. What is your current wheel set-up ?
Old 04-03-2013, 01:41 PM   #15
Grim1ock77's Avatar
I purchased 14mm rear and 7 mm front H&R spacers through a friend. Unfortunately I have not had a chance to install them yet. Was planning to paint the calipers and install the spacers at the same time, just waiting for the weather to warm up (for more than 1 day.....damn Ohio weather).
______________________
1999 Black Boxster
Grim1ock77 is offline   Reply With Quote
Old 04-03-2013, 04:29 PM   #16
Newb
V-Rod's Avatar
I have stock 17" turbo wheels and new stock size Hankook Ventus V12 evo K110's.
Old 04-03-2013, 05:28 PM   #17
What are the offsets ?
Old 04-03-2013, 05:53 PM   #18
Newb
V-Rod's Avatar
I don't know. Whatever was stock in 1999 on a base model. I am in Ohio right now, so I can not check.
