Originally Posted by Robsducati
Does anybody have wheel spacers fitted?
After looking at a couple of pictures of members cars, I quite like the wider look.
I was thinking 20mm rear, 15mm front.
Are there any noticeable handling compromises?
Do they put to much stress on wheel bearings?
What is the max width of spacer you can get away with?
I have 15mm front and back. Same sized wheels just out 15mm more. They do not protrude from the wheel wells and I have no rubbing issues with 17" stock Boxster wheels. Have yet to have any suspension problems with this set up. I also have M030 Sway bars front and rear. Handles real well with no lean on hard corners. They do tend to throw up a bit more road grime onto the rocker panels and rear fenders.
AKL
'02, Arctic Silver/Graphite Gray, 2.7, TIP, 2nd cat delete, Charlie Chan muffler,de-ambered, Braille Battery, clear tailights, painted bumperettes, clear third brake light, M030 sway bars, F shock tower braces, clear rear deck, '03 side vents.  15mm spacers fore & aft.
