Old 03-26-2013, 07:38 AM   #21
They may not look as sturdy, but the "fingers" do appear to be hub-centric, and pilot the wheel. The slots aren't an issue, since it's the wheel bolt clamping load, and the resulting friction between parts, that prevents "slipping" on the hub, not the acutal bolt holes. If it were truly a shear fastener application, you would never use wheel bolts, but studs with no threads in the joint interface.
A quick Google as an example: http://www.maximummotorsports.com/store/index.php?main_page=tech_wheels_spacers
Old 03-26-2013, 07:46 AM   #22
The fingers are there so it can be used on early cars. Which is why the holes are ob-longed. This is the only hub centric spacer that is made in sizes less than 15mm. You can spout off all you want but you opinion is just that an opinion, not backed by any knowledge or fact. It is ashame that the internet has because a place where ideas are based off of how many posts you leave and not by fact.
I would much rather utilize a spacer that was both bolt centric and hub centric, than one that relied on "fingers" alone. Your choice.
porshaowner is offline   Reply With Quote
Old 03-26-2013, 08:30 AM   #23
Johnny Danger's Avatar
How is it that this is the only hubcentric spacer that is made in sizes less then 15mm ? Also, I don't want a spacer that's designed to work with "earlier cars", I want one that replicates the technology of my current Porsche, wherein the spacers are both bolt and hub centric. Furthermore, never mind how many posts I have, the real shame here is that the internet allows someone to simply sign up to a forum and immediately start endorsing products without knowing jack !
Old 03-26-2013, 08:40 AM   #24
What are these ? Hemorrhoid cushions ?
Old 04-01-2013, 05:22 PM   #25
Newb
V-Rod's Avatar
Originally Posted by Allen K. Littlefield View Post
I have 15mm front and back. Same sized wheels just out 15mm more. They do not protrude from the wheel wells and I have no rubbing issues with 17" stock Boxster wheels. Have yet to have any suspension problems with this set up. I also have M030 Sway bars front and rear. Handles real well with no lean on hard corners. They do tend to throw up a bit more road grime onto the rocker panels and rear fenders.
AKL
Allen,
Do you have any pictures of your boxster with 15mm spacers and stock 17's all around? Do you have the stock or ROW M030 suspension?
1999 Boxster Ocean Blue Metallic/Savannah Beige
2001 Harley Davidson Road King w/Ultra Kit Black/Chrome
2004 Jaguar XJ8 Seafrost Metallic Green/Sand
2008 Land Rover LR3 Alaska White/Alpaca
2012 Honda Odyssey Touring Dk Grey/Lt Grey
V-Rod is offline   Reply With Quote
Old 04-01-2013, 05:32 PM   #26
Newb
V-Rod's Avatar
I am having my suspension updated to the row m030 next week and like the look of a wider stance but do not want to effect accelerated wear on tires, bearings or components. what is the recommended set of spacers. JD?
Old 04-01-2013, 05:44 PM   #27
Given the proper application, accelerated wear on tires, bearing and or other components caused by spacers is a myth. What is your current wheel set-up ?
Old 04-03-2013, 01:41 PM   #28
Grim1ock77's Avatar
I purchased 14mm rear and 7 mm front H&R spacers through a friend. Unfortunately I have not had a chance to install them yet. Was planning to paint the calipers and install the spacers at the same time, just waiting for the weather to warm up (for more than 1 day.....damn Ohio weather).
______________________
1999 Black Boxster
Grim1ock77 is offline   Reply With Quote
Old 04-03-2013, 04:29 PM   #29
Newb
V-Rod's Avatar
I have stock 17" turbo wheels and new stock size Hankook Ventus V12 evo K110's.
Old 04-03-2013, 05:28 PM   #30
What are the offsets ?
Old 04-03-2013, 05:53 PM   #31
Newb
V-Rod's Avatar
I don't know. Whatever was stock in 1999 on a base model. I am in Ohio right now, so I can not check.
