Old 11-23-2015, 07:59 AM   #21
1999 base
Meir's Avatar
do you have a picture of the re foamd flap back in place?
Old 11-23-2015, 08:52 AM   #22
2003 Base 5-speed
grc0456's Avatar
No, i didn't take a picture of that. I do recall the small side of the mixer door (with single row of holes) was facing into the heater core space , but maybe it was placed incorrectly. My thought is its not pivoting. I guess I could take it all apart again to compare to the pic I had of the door before I took it out, but I am not relishing that at this point! I am going away for Thanksgiving and may decide to do that when I come back, or just take it to the dealer to fix and probably chuckle at another DIY gone bad
You have been very helpful and kind, Meir. Thanks!
Old 11-24-2015, 05:47 PM   #23
1999 base
Meir's Avatar
The reason I asked, is becaus it looks liked you warped the flap on both sides.
Not only that, from the picture it looks like the new foam is wraped around the edge of the flap. I believe it create friction between the flap and the box, so the flap cannot move.
I whould give it another chance (after thanksgiving :chicken.
Try to reform the flap again. I will post a pic of the foam I used.
You can get it at Home Depot.
Old 11-25-2015, 02:15 AM   #24
2003 Base 5-speed
grc0456's Avatar
Oh, I thought the DIY indicated to wrap the foam around the edges to create a "seal" effect (i.e. to prevent air going around the sides). But what you say makes sense to me. I suspect the door is stuck, or not properly seated.
I sent the car of to my indie today, along with my pics and the DIY document. I hope they can sort it out. I'll let you know.
Again, thanks for your input, Meir. Happy Thanksgiving to you and yours!
Old 11-25-2015, 09:42 AM   #25
1999 base
Meir's Avatar
happy thanksgiving to you and all forum members.
just in case, here is a pic of the foam i used:
looking at my pics i noticed i re foamed the flaps on both sides as well, but i trimmed the foam at the edges.
Old 12-01-2015, 02:26 PM   #26
2003 Base 5-speed
grc0456's Avatar
Problem resolved
I have heat! Now measures 124F when at running temp on HIGH.
The DIY would have worked if I was a little more patient or skilled. The bushing at the bottom of the mixer door axis was cracked, causing the door not to pivot when activated by the servo motor. Not sure if I damaged it during reassembly (it was very tricky to remount the door), or if it had been broken all along. The problem area is located under the circle accessed from the under dash in passenger footwell:
The indie was able to repair the bushing - hopefully - for a long term fix. They had never heard of this foam/mixer door problem, so they learned something. Maybe because it is not as common in colder climates. My car was born and raised in FL. Cost was 4 hours labor.
Old 12-04-2015, 06:08 PM   #27
1999 base
Meir's Avatar
Glad to see you sort it out.
:dance:
Old 12-05-2015, 01:23 AM   #28
2003 Base 5-speed
grc0456's Avatar
:dance:
LOL, yes! The indie sorted it out for me for $400. Oh well, like you said - try it myself and if it fails then - I was going to pay anyway.
But seriously, I feel like I learned a lot about the car and, actually, the indie learned something new too. They had never seen this problem before as I guess the foam doesn't deteriorate over time up north like it does in the south.
Thanks for your help, Meir!
Old 03-20-2016, 09:03 AM   #29
I have a 1999 Boxster with the vent debris problem. I currently have the dash off for an unrelated issue, and decided to look into the debris problem at the same time. I'm trying to decide if I go down the full disassembly route or not, and have a couple of questions about the two different options. As I understand it, the options are:
1) Easy option - single flap repair. Access the hot/cold mixer flap from the front trunk. Flap is removed by using dremel tool to cut away flap upper bushing housing. Flap is removed through hole where heater core is mounted. Re-foam single flap. Reassemble.
2) Difficult option - dual flap repair. Remove heater core from front trunk, remove dash and dash mounting structure, evacuate A/C system, remove entire HVAC assembly from passenger compartment, disassemble HVAC housing. Re-foam both flaps. Reassemble.
Is this an accurate summary of the two options? If so, what does the second flap do? Is it for switching air between footwell/dash/defrost? Or outside air/recirculated air?
I'm thinking it's a better use of my time to skip the full repair option, to not further disassemble the dash, skip evacuating/refilling the A/C, and just re-foam the one flap from the front trunk. But I want to make sure I'm not missing some obvious justification for doing the full disassembly.
FYI, here's a picture of the flaps, taken through the passenger compartment center vent location.
Thanks in advance!
Carlton Bale is offline   Reply With Quote
Old 03-20-2016, 09:25 AM   #30
2003 Base 5-speed
grc0456's Avatar
Boy, option 2 seems like an awful lot of work to me.
Let Meir chime in or PM him. He really knows this issue and I think has had the dash completely out.
Me, I just wanted heat - and to stop the foam debris from blowing everywhere - and option 1 worked.
Old 03-20-2016, 04:19 PM   #31
1999 base
Meir's Avatar
Hi Carlton.
Your summery is pretty accurate.
In both option 1&2, you are reforming the flap the directs the air from the AC blower fan, to the heater core or the evaporator.
The other flap, directs the air between upper and lower AC ducts.
The circulation is controls by a third flap that doesn't need to be reformed.
It has a thick foam that doesn't disintegrate.
So to answer your question, you will get the same result with option 1 and 2 with everything related to the heat/cold control.
I have never tried option one, but can tell you that option 2 took me about 4 hours to compleate (after the dash was out).
In my case reforming was just "while I'm in there" kind of thing, as I needed to replace the leaking evaporator. So I never really evaluated option 1.
If to be honest, I have the same issue (foam flakes) in my C2.
At the moment I have no intention of attending it.
But that is easy to say when I need to use the heat twice a year (if at all).
Old 03-21-2016, 12:24 PM   #32
Thanks for the feedback! I'm starting reassembly of the dash and will deal with the re-foaming through the front trunk at a later time...
Old 04-20-2016, 12:51 PM   #33
Would this foam cause the heater to not blow as warm as it should?
professorman is online now   Reply With Quote
Old 04-20-2016, 01:06 PM   #34
Yes. The flap has large holes that are covered by the foam. If the foam is missing, the flap won't divert as much incoming air over the heater core, causing low temps.
Old 04-20-2016, 01:21 PM   #35
Sorry, Markus
Old 09-10-2016, 09:52 AM   #36
So I've had this foam deterioration for a while but never understood why. Now I know. I live in central TX, so it's not about getting warm air in winter for me. The issue I am having (other than years of foam bits coming out of the vents) is that the AC blows cold air out of the defrost duct vents even though my AC control is set to blow air only out of the center/side dash vents. What this does is cool the windshield, and I get condensation on the outside of the windshield, along the bottom where the glass is cold.
I have tested the AC control settings. I get air through the center/side ducts no matter what. With all controls in the off position, but AC running, air comes out of center ducts and the defrost ducts. If I turn on the footwell ducts, air stops coming from the defrost ducts and out the footwell ducts. This tells me the defrost/footwell flap is working. Working the various combinations, it looks like the center/side ducts flap is not working correctly. It is not closing off completely the access to the defrost/footwell ducts, like it should if you want all air to come out the center/side ducts.
I am trying to figure out if all the flaps have this foam, in which case that is likely my problem, or if there is something else wrong that is preventing the center/side duct flap from functioning correctly.
Pbastian is offline   Reply With Quote
Old 11-01-2016, 06:40 PM   #37
78F350's Avatar
There has to be another way...
At first I just had foam blowing out the vents, but after about a year, there was no hot air and on cold mornings, the windshield would frost back up. I quit driving that car on cold days.
I first saw Meir's DIY about two years ago. I downloaded the .pdfs and studied them getting ready to do the job. Great work and well documented. Recently I decided to stop putting it off and get the job done. I pulled the HVAC unit from my parts car off the shelf and used it for a visual aid. Looking it over, I came up with another way to access the flaps.
The flaps are behind a duct behind the dashboard center console.
I tried to see if there was a way to move it without removing the dashboard, but it can't be done.
With that duct out of the way, the flaps are accessible. How to get there....?
Old 11-01-2016, 06:50 PM   #38
78F350's Avatar
Another way:
  1. I ended up pulling out the console, which had already been modified for a 2 DIN head unit.
  2. Cut the duct so I could peel it down out of the way and temporarily taped it.
  3. My foam was COMPLETELY gone, otherwise I would have cleaned the flaps.
  4. Covered the flaps with a heavy duct tape that has a long lasting, thick adhesive.
  5. Tested the operation to make sure nothing was blocked and the tape was secure.
  6. Put it back together and used the same tape to seal the duct.
Relatively quick and painless. YMMV depending on your center console configuration.:dance:
Old 11-02-2016, 03:28 AM   #39
This is awesome. Seems like relatively easy access to both flaps.
No issues getting your hands/arms in the hole to the bottoms of the flaps?
Old 11-02-2016, 06:21 AM   #40
78F350's Avatar
I used strips of tape that were between two and four inches long. At first I tried poking them in with a trim tool, but using my hand worked best. With the flaps in the resting position, it was difficult, but doable. I think that the best access was with the AC running and the fan on low. I poked my camera in for this shot, then put on one more piece of tape to caver a gap:
Tags
foam , vent
