Old 01-16-2013, 02:16 PM   #1
Cool HiTag2 V3.1 KEY TOOL
Hi, anybody ever used HiTag2 V3.1 KEY TOOL and can this tool program a key fob that i no 24 digit code for.
the1andonly is offline   Reply With Quote
Old 01-16-2013, 02:38 PM   #2
1999 base
Meir's Avatar
i'm not familiar with this tool, but just by reading its description, i don't think it will work.
this tool programs the key fob.
in other words it writs the code of the alarm to the key.
in the boxster its the other way around.
the fob comes with preset code, and the dealer enters that cod to the alarm/immobilizer/ecu.
for that reason if you buy a fob from ebay, make sure it comes with a code. without it, it is useless.
Old 12-14-2014, 10:35 PM   #3
PIWIS tool
This can be done only using a PIWIS cable, available at the dealer (like this one $27) or at a qualified Porche garage.
Try also the following reset:
turn ignition on,
turn off.
remove the transponder from the column
push any button on the fob within 6 seconds.
This procedure will reset the key synchronizing again with the vehicle computer.
Dave1987 is offline   Reply With Quote
Old 12-15-2014, 06:50 AM   #4
JayG's Avatar
That ain't no PIWIS!
It's a knockoff clone Durametric that probably won't work
In any case it won't program a key to a 986
Old 12-16-2014, 10:26 AM   #5
inveniam viam aut faciam
I think that you will find a lot of Chinese sites that make broad claims as to the capabilities of their cheap knockoff tools. They know that there is little chance of them refunding money, so it really doesn't matter if the stuff does or does not do what is claimed.
My guess is that the functionality that that specific tool has is for the Kessy system used on Cayennes with keyless entry. As far as I know there is NO tool that will generate the transponder code that is used on the 9x6s.
Qmulus is offline   Reply With Quote
Tags
key programing
