Old 01-02-2013, 02:54 PM   #1
Wheel noise?
Just purchased my first Porsche! '02 Boxster. I'm noticing a high pitched whine /*0009 after I reach about 25 mph...seems to be speed dependent so I'm assuming it's coming from one of the wheels. Has anyone had a similar issue? I'm having a four wheel alignment this weekend and will quiz the mechanic on it.
afpa66 is offline   Reply With Quote
Old 01-02-2013, 03:43 PM   #2
1999 base
Meir's Avatar
Sounds like a wheel bearing.
Put the car on jack stand, and push each wheel from top and bottom, in and out.
If you have " play ", the bearing is bad.
Old 01-02-2013, 04:30 PM   #3
Smile wheel noise
Tires checked ?
t2-bxtrs is online now   Reply With Quote
Old 01-05-2013, 10:25 PM   #4
My 02S had a rear bearing go at 40, 000 mi. The whine or roar gets worse with time and is speed dependent. You can usually hear a gritty sound when rotating the tire when on a lift.
opus69 is offline   Reply With Quote
Old 01-06-2013, 06:53 AM   #5
oc-boxster's Avatar
just fixed the same issue in my 02S right rear wheel bearing gradually got so loud i couldnt hardly stand to drive it-there was no play in the wheel when jacked up and moved around-my mechanic replaced for 377.00 parts and labor-he said its very common for rear bearings to fail in 2000-2002S models especially the right rear he told me he has replaced alot of them-get it done and youll enjoy a much smoother queiter ride.
oc-boxster is offline   Reply With Quote
Old 01-06-2013, 09:13 AM   #6
SC-986's Avatar
Had the same problem about a year ago on my '02 base. Whining noise coming from passenger side rear wheel area. Could not get a definitive diagnosis that it was indeed the wheel bearing.
I ended up having the rt. rear wheel bearing replaced hoping that would take care of the problem. Bearing replaced - noise gone.
SC-986 is offline   Reply With Quote
Old 01-07-2013, 02:40 AM   #7
Very interesting since it was also my right rear bearing that went bad on a 2002S. I went ahead and replaced all four bearings, thinking if one was bad the others were probably not too far behind.
Old 01-07-2013, 08:09 AM   #8
HAUSIDMT's Avatar
+1 on the wheel bearing issue. I got it all handled myself except for pressing the new bearing in. $50 got me the bearing pressed and he hot washed all the parts, came back looking like brand new. Ironically enough it was also my R side bearing on a '02S.
2002 Boxster S with a few goodies, my 2nd Porsche.
1st was a 1966 912 hand me down from pops
HAUSIDMT is offline   Reply With Quote
