Old 08-13-2012, 10:30 AM   #1
Camshaft position deviation
Camshaft position 1 deviation varies at idle between -3.43 and -3.06 or wider. Camshart position 2 deviation stays at -1.95. IMS was replaced several months ago so I think it is not likely IMS bearing. What else could cause this and how risky is this?
opus69 is offline   Reply With Quote
Old 08-13-2012, 10:47 AM   #2
Actually, it is quite normal. What you are seeing is wear/slop in the cam drives and VarioCam system that is always there.
Old 08-13-2012, 03:51 PM   #3
Thanks for the feedback. The car runs great I just like to keep it that way.
Old 08-13-2012, 07:27 PM   #4
Engine Surgeon
If the engine is a 5 chain the variorum wear pads are probably worn.. If its a 3 chain the cam timing is off and could have slipped the 4-6 sprocket on the IMS drive tube. The deviations aren't huge at all, just keep a watch on them.
US Patent 8,992,089 &
US Patent 9,416,697
Old 08-15-2012, 02:47 AM   #5
Location: Seattle - It's not Hell, but you can see it from here!
is there any easy way to determine if you have a 3 or 5 chain engine?
dave
2001 Porsche Boxster S
1988 Porsche 928 S4
Dave928 is offline   Reply With Quote
Old 08-15-2012, 03:36 AM   #6
By year, if your car is a 2001, it is a five chain motor.
