06-24-2012, 05:35 AM
Headlights
Will a set of 99 911 headlights fit a 2001 Boxster, Let me know if you have any information. Thanks
06-24-2012, 08:01 AM
The easiest way to tell is look up the part numbers and see if they match.
06-24-2012, 08:03 AM
yes. but get a matching set. the trim color is different - it's clear for the boxster and silver for the 911. i have 1 that i used as a replacement for a yellowed light.
06-24-2012, 08:05 AM
Or, if you're close to where those headlights are, give 'em a test fit and see how they mate up.
07-08-2012, 12:33 PM
Are you sure that's the case?
Look the same to me...
07-08-2012, 12:47 PM
quite.
from the 911:
from the boxster:
on the 911, the part that's not clear for the light to shine through has a silver backing. on the boxster, the entire lens is clear. (look at the "ribbed" portion)...
07-08-2012, 12:58 PM
suppose it doesn't matter, since the OP is talking about getting a set, not 1 replacement. so do they fit? yes.
07-08-2012, 01:00 PM
No, sure. I see that the lights you have here are different. But are all 996 lights like that?
07-08-2012, 01:59 PM
ok so a little more looking around appears that mine might be from a '97, not a '99, since those can be "deambered" - don't know why i haven't thought of that until now...
Headlight Assembly With Integrated Turn Signal, Right
Brand: Genuine PORSCHE
Applications: 996 Carrera (through 7/98), Each
the '99's the OP is looking at should appear like this
07-08-2012, 04:04 PM
only 2003-2004 can be deambered and that picture you posted above is from a 03-04
07-08-2012, 06:09 PM
Tonycarreon,
Maybe you should sell your passenger side light for cheap (to me, of course) and buy the silver one to match your new driver's side?
07-08-2012, 07:49 PM
if you're talking about boxster, but the 996 headlights were a few years ahead....
