Old 03-07-2012, 12:18 AM   #1
Revs not dropping between shifts
My 2.7 egas has a problem where the revs don't drop immediately when you take you foot off the throttle. As an example between shifts the revs tend to slowly drop rather than immediately.
Shouldn't be the throttle body as I cleaned it less than 5,000 Kms ago. Is it likely to be the MAF, or something else?
http://i13.tinypic.com/49ied5h.jpg
2000 2.7 Boxster
aussieboxy is offline   Reply With Quote
Old 03-07-2012, 09:44 AM   #2
Opposed to Subie Burble
Overdrive's Avatar
bit more info for us...
5-Speed or Tiptronic?
Does the same thing happen when you just apply the throttle in neutral/when parked?
-O/D
IMSR + RMS
Robbins glass window top
Old 03-07-2012, 09:49 AM   #3
Could be as simple as your floor mat, but I doubt it.
Old 03-08-2012, 02:00 AM   #4
It's a manual & yes Overdrive it does. Unfortunately its not the floor mat Flavor, good thought though. I did check that after your suggestion.
2000 2.7 Boxster
Old 03-08-2012, 06:53 AM   #5
Overdrive's Avatar
How about the pedal's travel? Does it come right back up with your foot when you lift or is it kind of slow? I'm wondering if your input behind the gas pedal is worn out/gummed up/out of adjustment and the throttle is reacting accordingly as though you were slowly lifting off the throttle instead.. I don't have e-gas experience, but that's what comes to mind thinking about it logically.
-O/D
IMSR + RMS
Old 03-10-2012, 04:20 AM   #6
Rennzenn
j.fro's Avatar
I've had a similar issue. Check for vacuum leaks after the throttle body: the hose connecting the AOS to the intake plenum, the TB seal to the plenum, and the large rubber connectors between the plenum "T" and the "fingers"
Old 03-19-2012, 01:49 PM   #7
Overdrive's Avatar
Any news on your issue, aussieboxy?
-O/D
IMSR + RMS
Old 05-02-2012, 03:35 AM   #8
Still trying to find an easy way to detect vacuum leaks
2000 2.7 Boxster
Old 05-02-2012, 06:17 AM   #9
pedal
I replaced my entire pedal when the bottom hinge had broken and it solved many problems, also making the response better. If I can remember the revs did drop quicker on releasing the pedal after installing the new pedal. I would take the pedal apart and trace for loose/worn parts, it would be a logical place to start before moving to the throttle.
de-snorkeled, clear lights, sports exhaust, zeintec hard top, zein wing, B&M short shifter, DesignTek lowering springs, DesignTek carbon fibre strut brace front and rear, 18'' carerra 5 spokes, semi slick tyres, entire soft top delete, engine cover delete,red console,L&N deep sump, volo performance chip, raptor shift light, de-cat'ed, OEM GT3 bucket seats.
sickbananas is offline   Reply With Quote
Old 05-03-2012, 02:27 AM   #10
Check the codes too.
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
1990 Land Rover Defender 6x6
