Old 03-05-2012, 11:18 AM   #1
Lock cylinder broken
Recently I had the lock cylinder break or at least it seems. The key turns freely in the lock. Both doors lock using the lock button in the car which has me a little confused. I thought if the cylinder was broken likely the door wouldn't lock at all. Is there an easy fix for this? I get the feeling this will require a dealership visit
Earn is offline   Reply With Quote
Old 03-06-2012, 10:54 AM   #2
Chirp Chirp Chirp
Old 03-06-2012, 03:15 PM   #3
1999 base
Meir's Avatar
not necessarily
the lock and the cylinder are two different mechanism.
this is the cylinder (part 15):
Porsche Boxster Door Handle Parts
this is the lock it self (part 14):
Porsche Boxster Door In White Parts
if you look at part 15, you will see a shaft coming out of it.
maybe that's the broken part.
this way or the other, take off the door cover and have a look.
your lock mechanism is definitely good, if you can lock and unlock by using the button.
Old 03-06-2012, 04:17 PM   #4
Great thanks for the help!
Old 06-04-2014, 10:26 AM   #5
Hi, I disassembled the lock cylinder/paddle/spring last week and ordered the $22 metal ring that was broken. I am now trying to reassemble the paddle and spring to the lock cylinder and I'm having difficulty. Can anyone share info on reassembly?
I wish I had taken some pics...but with the broken part I'm not sure the alignment would have been correct anyway.
Thanks, David.
dbeesley1 is offline   Reply With Quote
Old 06-09-2014, 05:48 PM   #6
I had to fix the whole thing 2 years ago. Go to pelican. I seem to remember one of their articles on the subject. The spring was a pain. I also remember pushing in the paddle to release the ring. I even change the tumblers from 1 lock to the other. I was a little concerned but it all worked out.
'99 Boxster Artic Silver/Red
'14 Subaru Outback
'06 EG Classic
'05 Sportster
