02-22-2012, 08:09 AM
#1
Need long lug nuts
02-22-2012, 08:39 AM
#2
When I ordered my H&R 23mm spacers, I ordered the appropriate H&R lugs as well. They are very well made and have floating "acorns" for a proper seat. I got mine from Vivid Racing. You need to have 15mm of thread in the hub, I can't remember exactly what size I ordered. If I dig it up, I'll let you know.
2003 Cayenne Turbo
02-22-2012, 08:42 AM
#3
Found it, I used 54mm thread bolts. Vivid part number was 1455407, not sure if that crosses over to H&R as well.
2003 Cayenne Turbo
02-22-2012, 08:44 AM
#4
02-22-2012, 09:29 AM
#5
Porschephile
What some bolt manufacturers will specify is "OEM +XXmm" the XX being the spacer thickness.
This is a good source my Googling turned up:
Otis Inc LA
RAD USA Direct
toll-free 855.OTIS.INC (684.7462)
toll-free 888.RAD.BOLT (723.2658)
international +01.310.995.8939
fax 310.305.0465
otisincla.com Home
Home
'06 Boxster 2.7
02-22-2012, 08:43 AM
#6
02-22-2012, 08:09 PM
#7
wow - wheel bolts that are +1" (+50%) longer than OEM... sound like you would be better off (safer) w/ a different style of spacer... aka not sandwich style...
I don't know the technical specs but that seems like it would be pushing the limits, no?
Good luck
02-23-2012, 12:18 AM
#8
Try this eBay item #130541540457 Nice two piece bolts.$99 for 10
02-23-2012, 03:10 AM
#9
Reason: FI: 53mm long bolts are needed for 23mm spacers
02-23-2012, 04:19 AM
#10
For future reference, the standard length of the oem lug bolt is 28mm's . Therefore, the following formula can be applied:
28mm + the thickness of the spacer = length of the lug bolt
02-23-2012, 03:03 AM
#11
02-23-2012, 09:01 AM
#12
Originally Posted by madmods
What on earth.... where did anyone ask about safety or different style of spacers in that thread?! I'm talking about the wheels bolts mate. Was hoping to hear if anyone could share a source for good 2 piece wheel bolts that fits a 23mm spacer.
And in which friggin world you are where one would use sandwiches as wheel spacers exactly?
Bloody hell.... is it just me or this was spooky
Saftey, if for no one else but yourself is obviously important. I'm by no means the safety police but especially if you track your car or run it very hard, you need to take it into consideration. That said, there are for all intents and purposes, two styles of wheel spacers:
"sandwich" ones which utilize longer wheel bolts to hold them between the wheel & rotor/hub almost like a washer:
and bolt on which, as name implies, bolt on to rotor/hub and then (either using studs/lug nuts or a second set of wheel bolts) have wheels mounted to the spacer.
Reason being, wheels bolts have a recommended length to thickness ratio for tensile strength. Longer bolts, to maintain this ratio for safety either need to be thicker, made from a stronger material or have more of them. With a longer bolt, the wheel exerts more leverage which can result in bending or snapping of the bolt.
My understanding is pretty much anything over 20mm, for safety, requires bolt on not sandwich style. By your language though, it sounds like you are not concerned about performance but purely cosmetics.
Good luck
02-23-2012, 11:37 AM
#13
I agree with Burg, when one starts to get into some really large spacers, the prudent choice would be to utilize the "spacer and stud" design .
02-23-2012, 11:39 AM
#14
Buy studs...
02-23-2012, 12:12 PM
#15
interesting I am on the track with 23mm spacers on the rear. I used the H and R bolts. I am not sure of the material they use.
would it be best to install high grade studs in my hubs and use my current "sandwich" spacers?
986 00S
02-23-2012, 03:13 PM
#16
02-23-2012, 02:42 PM
#17
Anyone know where I can find "long" lug nuts to match a 23mm spacer? Nothing fancy, just some good quality lug nuts. Also, how long am I looking for? 50mm? 75mm? If anyone knows that would be brilliant.
I used the H and R bolts spec'ed for the Boxster S 23mm spacers. Sorry I cant recall my bolt lengths. You may want to consult the HandR web site as they have 23 spacers in their product line.
986 00S
02-23-2012, 03:17 PM
#18
02-23-2012, 03:27 PM
#19
looks like they worked perfectly for you....good luck!
986 00S
02-23-2012, 03:32 PM
#20
