		|  02-22-2012, 01:22 PM | #1 |
	| Registered User
				Another Wheel Question
			I have a chance to purchase a set of 2006 Boxster S Wheels they are 8x18 57 offset front, 9X18 43 offset rear,   my wheels are 7.5x18 50 offset front, 9x18 52 offset rear.  What do I need to do to make these wheels fit my 2001 Boxster S? Thanks
		|  02-22-2012, 02:32 PM | #2 |
	| Registered User
			The short answer is that they will fit fine. The fronts will be positioned slightly inward . However, the rears will be positioned a bit further out toward the fender . Depending how aggressive you want your "stance" to be, spacers can be added to augment this effect.
				__________________Don't worry … I've got the microfilm.
		|  02-22-2012, 02:54 PM | #3 |
	| Registered User
				Wheel
			Thank You very much, they're a lot smarter guys on here than me.
		|  02-22-2012, 10:54 PM | #4 |
	| Registered User
			what about some 18x 8.5 51mm
 18x10  63mm
 What would I need to make them fit?
 Thank you
		|  02-22-2012, 11:40 PM | #5 |
	| Registered User
					Originally Posted by SF-Rockster  what about some 18x 8.5 51mm
 18x10  63mm
 Thank you
Hi!
You need 23mm spacers for the rear wheels, so they will fit.
				__________________www.dynamic-speed.com
		|  02-23-2012, 09:35 AM | #6 |
	| Registered User
Thank you sir!
I'm going to order them now.
		|  02-23-2012, 10:29 AM | #7 |
	| Registered User
					Originally Posted by SF-Rockster  Thank you sir!I'm going to order them now.
Also you can order 7mm spacers for front!
Then you become this:
18x 8.5 51mm plus 7mm spacer = offset 46
18x10 63mm   plus 23mm spacer = offset 40
This configuration should be perfect, but keep in mind, to use only 225/40 in front and 265/35 for rear.
		|  02-23-2012, 11:31 AM | #8 |
	| Registered User
			Or you could use the 987 sizes of 235/40 and 265/40.
		|  02-23-2012, 11:54 AM | #9 |
	| Registered User
					Originally Posted by stephen wilson  Or you could use the 987 sizes of 235/40 and 265/40. |
Sorry, but these sizes are not for the 986 Boxster !
		|  02-23-2012, 12:32 PM | #10 |
	| Registered User
			OK, you have me confused. You recently posted in another thread that 18x11 wheels fit on a 986???
 The sizes I mentioned may not be OEM fitment to a 986, but by that logic you shouldn't use wheels from a 987 either.
		|  02-23-2012, 01:09 PM | #11 |
	| Registered User
					Originally Posted by stephen wilson  OK, you have me confused. You recently posted in another thread that 18x11 wheels fit on a 986???
Yes, that´s right! 11 x 18 will fit on 986, but there´s a lot of modifications to do and only with 265/35 possible.
For the 986, you can not use the 987 tire sizes, their not compatible.
		|  02-23-2012, 01:16 PM | #12 |
	| Registered User
As long as the wheels are hub centric (i.e. 71.6 center bore - which 986/987 wheels both are), then they're perfectly interchangeable . However, one has to carefully calculate how the difference in width and offset will effect the overall fitment between the two .
In the past, I've gone on record several times indicating that 10 inch wheel is about the widest that will properly fit on a 986 boxster .
		|  02-23-2012, 01:27 PM | #13 |
	| Registered User
			Sorry Johnny, I meant I was confused by Spyder's comments, I know the 986/987 wheels interchange, it's done all the time (and that the O/S has to be correct).
 The 987 sizes work fine, it's been done. They will be a touch taller, but not enough to cause a problem. Some may argue they fill out the wheel well a bit better.
		|  02-23-2012, 01:31 PM | #14 |
	| Registered User
					Originally Posted by Johnny Danger  As long as the wheels are hub centric (i.e. 71.6 center bore - which 986/987 wheels both are), then they're perfectly interchangeable . However, one has to carefully calculate how the difference in width and offset will effect the overall fitment between the two .In the past, I've gone on record several times indicating that 10 inch wheel is about the widest that will properly fit on a 986 boxster .
I think, it´s everyones personal taste, which widths he use... for my kind of taste, 10,0 or 10,5 was not enough. My new wheels are become the widths in front 9,0 and rear 11,0 again.
		|  02-23-2012, 01:47 PM | #15 |
	| Registered User
					Originally Posted by stephen wilson  Sorry Johnny, I meant I was confused by Spyder's comments, I know the 986/987 wheels interchange, it's done all the time (and that the O/S has to be correct).
As you probably know, it's the difference in tire size that changes the overall circumference between the two. Also, keep in mind that the oem wheels used on the 987 platform vehicles typically have a much higher offset than the 986 . And, depending on one's suspension set-up, this can pose inner clearance problems . Thus, necessitating the need for spacers .
		|  02-24-2012, 06:19 PM | #16 |
	| Registered User
			Thanks for all the help guys!I just bought a almost new set w/ new tires!
 SSR gt-03 18"
 love them on my car!
		|  02-04-2014, 03:02 AM | #17 |
	| Registered User
			911 Turbo 2004 18" wheels  will fits to Boxster 2001 S ?
tires sizes are:
18-225-40 front (I know its ok)
18-285-35 rear (285 its ok? I know needed 265-35)
		|  02-04-2014, 04:22 AM | #18 |
	| Registered User
					Originally Posted by travisn706  Thank You very much, they're a lot smarter guys on here than me. |
JD is our wheel expert, just don't ask him if 11 inch wheels will fit...he will implode.
	|  Posting Rules |
		You may not post new threads You may not post replies You may not post attachments You may not edit your posts
 |  |  |  All times are GMT -8. The time now is 05:53 AM.
