Old 02-23-2012, 01:47 PM   #21
jaykay's Avatar
I agree that the spacer/stud set-up is very practical; especially when it involves larger spacers that are used in track applications . However, a well designed spacer that is Porsche specific (i.e hub centric) will have an extended collar that will act as the hub . This along with the appropriate length lug bolts will provide an excellent interface .
Yeah...I seemed to recall a centric slide to transitional fit for the hub and wheel on the spacer when I put them on. Fully torqued, I would imagine that the loading the lug bolts would be predominantly tension.
986 00S
Old 02-23-2012, 02:13 PM   #22
madmods is offline   Reply With Quote
Old 02-23-2012, 02:17 PM   #23
Old 02-23-2012, 02:27 PM   #24
jaykay's Avatar
looks like they worked perfectly for you....good luck!
986 00S
Old 02-23-2012, 02:32 PM   #25
Old 02-27-2012, 02:49 PM   #26
manolo's Avatar
I looked into the stud style, but H&R only makes it in 21mm (and then way bigger sizes). I wanted 23mm so I had the option to run a 275 if I want (they are 993 hollow spokes in 18x10 ET65). They only make the sandwich style in 23mm so as it worked out I had to use the sandwich style. Wheel swaps would definitely be easier with the studs, but its not so bad. So far everything has worked flawlessly, and I beat the holy hell out of my car!! :-)
2003 Cayenne Turbo
manolo is offline   Reply With Quote
Old 02-27-2012, 02:56 PM   #27
Johnny Danger's Avatar
For future reference, the length of the standard oem lug bolt is 28 mm's . Here is a simple formula to follow when determining longer lugs to accommodate spacers :
* 28 mm's + the size of the spacer (i.e. thickness) = the length of the lug bolt needed .
Old 02-28-2012, 01:17 AM   #28
Old 02-28-2012, 01:33 AM   #29
Old 02-28-2012, 07:49 AM   #30
manolo's Avatar
Originally Posted by madmods View Post
PS: RE ur avatar.... love the R1 and the smoke coming off the knee puck Good taste!
HAHA! You can see that? I didn't know they were smoking until I saw the pics a week later. Apparently I wore them a bit too long and started overheating them, they were almost down to the velcro!
2003 Cayenne Turbo
Old 02-28-2012, 08:30 AM   #31
