Old 02-27-2012, 03:49 PM   #1
manolo's Avatar
I looked into the stud style, but H&R only makes it in 21mm (and then way bigger sizes). I wanted 23mm so I had the option to run a 275 if I want (they are 993 hollow spokes in 18x10 ET65). They only make the sandwich style in 23mm so as it worked out I had to use the sandwich style. Wheel swaps would definitely be easier with the studs, but its not so bad. So far everything has worked flawlessly, and I beat the holy hell out of my car!! :-)
2003 Cayenne Turbo
manolo is offline   Reply With Quote
Old 02-27-2012, 03:56 PM   #2
Johnny Danger's Avatar
For future reference, the length of the standard oem lug bolt is 28 mm's . Here is a simple formula to follow when determining longer lugs to accommodate spacers :
* 28 mm's + the size of the spacer (i.e. thickness) = the length of the lug bolt needed .
Old 02-28-2012, 02:33 AM   #3
madmods is offline   Reply With Quote
Old 02-28-2012, 08:49 AM   #4
manolo's Avatar
Originally Posted by madmods View Post
PS: RE ur avatar.... love the R1 and the smoke coming off the knee puck Good taste!
HAHA! You can see that? I didn't know they were smoking until I saw the pics a week later. Apparently I wore them a bit too long and started overheating them, they were almost down to the velcro!
2003 Cayenne Turbo
Old 02-28-2012, 09:30 AM   #5
Old 02-28-2012, 02:17 AM   #6
