Old 02-04-2012, 09:37 AM   #1
18" wheels
I have a 2001 Boxster S, it has factory 18" turbo twist on it now and I want to upgrade to a aftermarket wheel, what would I have to order to make sure the new 18" wheels fit. I'm looking for size front and back and offset information and anything else needed. Where is everything measured from? thanks in advance I'm new to the Boxster world, so I don't want to screw anything up.
travisn706 is offline   Reply With Quote
Old 02-04-2012, 09:55 AM   #2
18x8.5 front et52
18x10 rear et45
Are what I'm running
225/40/18
265/35/18
Splitpin is offline   Reply With Quote
Old 02-04-2012, 10:01 AM   #3
!8" wheels
What type wheels are you running, I have the same tire size also, what does the et52 mean?
Old 02-04-2012, 10:12 AM   #4
They are team dynamics pro race 1.3 in silver
ET is the wheels offset, the distance from the centreline of the wheel to the hub mounting face, the lower the number the further they stick out
Old 02-04-2012, 06:07 PM   #5
Pat
pictures? cost?
considering these myself
-Chuck Patterson
Old 02-04-2012, 09:54 PM   #6
Matt
MileHighBoxster's Avatar
If you're running factory wheels,the size, width and offset are on your current wheels. Start with that information.
Matt
2004 Boxster S, Guard's Red, 6 Speed
MileHighBoxster is offline   Reply With Quote
Old 02-05-2012, 04:56 AM   #7
do you have pics of the 18's? I am looking for a set. Also, what do you want for them, assuming you are getting rid of them
dennis is offline   Reply With Quote
Old 02-05-2012, 01:30 PM   #8
18" wheels
Thanks Milehigh, I'll pull one off and look for the information.
Old 02-05-2012, 01:31 PM   #9
I'll contact you when I'm ready to get the other set, I'm trying to be ready by the 1st of March.
Old 02-05-2012, 01:32 PM   #10
Matt
Removal shouldn't be necessary. It should be on either side of your valve stems. If not, it will be on the back side of the wheel.
Matt
Old 02-11-2012, 06:38 AM   #11
Porschephile
In general, you can eyeball the inner and outer clearances around the wheels/tires you have now and extrapolate to the new wheels.
From what I understand, 11" rear is pushing the limit of the wheel well clearance, with some people opting to use a 265-section tire instead of the more normal-for-11" 295 section. That can vary with tire brand/model since they do have different 'shoulder' profiles.
Splitpin's explanation of offset measurement is perfect. If you are going from a stock 10" wheel with (for instance) 45mm offset, you may end up with a better fit at a different offset number. You can change 'effective offset' by using spacers -- as long as the wheel offset number is higher than your target offset number.
For instance, many OE 11" wheels have a 65mm offset. You may need a 15 to 20mm spacer to fit the wheel correctly in the wheel well... If you have the luxury of a lift and time to experiment, I've seen people make a cardboard template of a tire, tape it to the rim and mount it up to check clearances.
'06 Boxster 2.7
techweenie is offline   Reply With Quote
Old 02-11-2012, 07:46 AM   #12
Old 02-11-2012, 10:29 AM   #13
LAP1DOUG's Avatar
If you are planning to run PCA autocross, you better check the rules before you buy anything.
Peachstate PCA uses Parade rules as a basis, and if you change to non-stock wheels of any size, you are out of the stock class, and into the Production Class, and if you go over 1" wider than stock you will be in the Improved or Modified Class, with very few competitors and heavily modified cars.
Kippis
986S
991S
Van Diemen RF97
Old 03-14-2013, 02:01 PM   #14
WheelDynamics's Avatar
Seen here in 19"
Also available seen here in 18"
WheelDynamics is offline   Reply With Quote
Old 03-14-2013, 04:25 PM   #15
DFW02S's Avatar
Is that a Prancing Pony badge on that Boxster?
DFW02S is offline   Reply With Quote
Old 03-14-2013, 05:41 PM   #16
1999 base
Meir's Avatar
Nice catch
Old 03-15-2013, 09:00 AM   #17
BYprodriver's Avatar
And if you like the way the car drives now, deviate from your baseline specs as little as possible for the "upgrade"
Old 03-19-2013, 09:19 PM   #18
Not sure, it was a customer submitted photo sent in to us... Sure looks like it...
