Old 02-01-2012, 11:12 AM   #1
changing the battery on 2000 s
What is the procedure for changing the battery on my boxster. I'm new to the car. Never had to deal with reseting the computer. Would appreciate any help.
Jim M. is offline   Reply With Quote
Old 02-01-2012, 01:55 PM   #2
Johnny Danger's Avatar
Take the old one out, and put the new one in . The DME will be unaltered by this .
Old 02-03-2012, 06:13 AM   #3
Actually, that is not correct. The DME will lose all active and pending codes, as well as its adaptive settings. The car may run a bit rough until it "relearns the " these settings. This is why a lot of shops put the car on a system retains power while the battery is out, so nothing is lost. On some 911 variants, the car can actually lose the calibration settings for the fuel level when changing the battery, requiring the system be re calibrated, which is a major pain in the butt...........
Old 02-01-2012, 03:13 PM   #4
Steve Tinker's Avatar
Negative (-) cable off first, then the positive (+) cable.
(+) on first, then (-) on installation of new battery.
Just make sure you have your radio code before you disconnect the battery......
2001 MV Agusta F4.
Old 02-03-2012, 03:43 AM   #5
oh nice one mate. I didn't know that. You just can't NOT love this forum
madmods is offline   Reply With Quote
Old 02-01-2012, 03:40 PM   #6
Take out the battery tray and clean all around it with a weak baking soda solution and flush liberally with water. If the tray is rusted, sand it it, prime it and paint with rustoleum. Spray the tray and everything underneath it liberally with wd40.
While you're in there, clean out the body drains.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 02-02-2012, 06:57 AM   #7
Thanks for the help.
Old 02-02-2012, 06:41 PM   #8
Idaho Red Rocket 3's Avatar
How do you get the radio code ?
2000 Boxster S
Old 02-02-2012, 06:50 PM   #9
WV Boxster
wvboxst3r's Avatar
you need radio serial number and vin number then hope your dealer is nice and will give you code at no charge. Call around they will do it. My local and next two wanted 50 bucks. Found a dealer near beach house that did it for free.
If your not LIVIN now, then when?
wvboxst3r is offline   Reply With Quote
Old 02-02-2012, 11:47 PM   #10
1999 base
Meir's Avatar
Or just try this.
Lost Radio Code - post your request here - RennTech.org Forums
Old 02-03-2012, 06:28 AM   #11
I'm learning so much more in a day than I can imagine, I think!
Silly question I'm sure; could a plain 12v battery charger be used as a power retaining system?
Old 02-03-2012, 07:29 AM   #12
No, it will try to pass too much current (amperage) for the system to deal with. You need something like a Ctek 7200 battery maintainer, which has a specific "supply mode" setting specifically for this purpose; while plugged into the lighter socket, it supplies the correct voltage at low current and without the voltage "ripple" normal battery charger's put out.
Just remember: When connected to the Ctek in the supply mode, your battery positive cables remain "hot" even when disconnected, so they should be wrapped in a non conductive material, like a plastic or rubber bag, to prevent it from shorting while you pull out the battery.
Old 02-03-2012, 07:59 AM   #13
So.... that's how to change a Porsche battery in a 2000 s
The OP had a genuine question after all. Very good one actually! Thx to JFP for the "pro" and final touch i.e. "positive cables remain "hot"". *Noted*
Top quality
Old 02-03-2012, 08:40 AM   #14
Schatten-Baum-Mechaniker
I've used one of these to save codes etc. during a battery change.
9 Volt Battery Computer Memory Saver - xxxw-kas295a
Tommy
2000 Boxster S
1973 914
tommy986 is offline   Reply With Quote
Old 02-03-2012, 08:50 AM   #15
They also can work, but are not as dependable as a proper power supply as the battery starts off at a lower voltage (9V), and the battery can weaken due to age, resulting in the same issues as not having anything. Some OEM systems also do not hold their settings very well at 9V. For a "one off" battery swap, they can work; but for a shop, or if one is about to buy a new maintainer, looking for one that can do a proper "supply mode" is a good investment as they will work on any car.
