Performance and Technical Chat
Removing airbag cover.
01-19-2012, 02:19 PM
E500W124
Hello.
Need help with a common horn failure.
Guess I need to replace the airbag retaining frame, but can't remove the cover.
How do I remove this steering wheel/airbag cover?
Did try to pull it off but was afraid to damage the cover.
01-19-2012, 02:23 PM
2
Burg Boxster
unscrew from behind
after
disconnecting battery...
use the search feature for more details and a DIY... probably w/ pictures too
01-19-2012, 02:28 PM
3
E500W124
Originally Posted by
Burg Boxster
unscrew from behind
after
Thanks.
Will give the search another try.
Linear Mode
Switch to Threaded Mode
09:22 PM
Privacy Statement
Terms of Service
