01-18-2012, 12:57 PM
Does handling improve with wheel spacers?
Specifically, will 7mm spacers on the fronts improve handling because of the wider stance of the front wheels?
Thanks.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
01-18-2012, 01:06 PM
Porscheectomy
The effective spring rate is reduced slightly due to the longer lever arm. You will never notice the difference.
01-18-2012, 01:12 PM
You'll get a wide range of opinions on this application. However, most would agree that spacers are typically used in order to augment wheel fitment or for aesthetic reasons rather than for handling issues . Although, I guess that one could argue that they are one in the same .
01-18-2012, 01:32 PM
If you are autocrossing or track driving at the very top of your class and trying to get that last 0.01% out of the car, then yes, this might *theoretically* improve handling.
Otherwise, you'll never notice the difference.
01-18-2012, 01:33 PM
I have a 2000 2.7l as well and I installed spacers last year.7mm at the front and 15 mm at the back.There could be a slight better handling feeling..The wide stance is what I wanted and they are a perfect fit with the standard wheel offset .I love the look and the fenders seems to flow to the wheels.Very happy with them.
01-18-2012, 02:11 PM
I have 15s up front and feel the front end is less twitchy, more firmly plant as a result. The tire contact patch is moved out board. The front track is slightly wider. Theoretically the roll centre(s) will move. This gives you a change in roll moment depending upon whether the distance to the longitudinal cofg axis changes
986 00S
01-18-2012, 04:33 PM
Edumucate me. What does this mean?
Current car
Previous cars
1973 Opel Manta
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1993 Saab 9000
01-18-2012, 04:35 PM
Porscheectomy
Basically, roll center is the point at which the suspension moves about. Think of it like the center of wheel, it's the point where there is no displacement, only rotation. The center of gravity works on the roll center to lean the car through a turn.
http://i24.photobucket.com/albums/c25/Turbo711/Rollcenter.jpg
01-18-2012, 05:30 PM
It is 7mm per side or 14mm total and that is a half an inch. Will it make a difference, sure every little bit makes a difference but could you tell if you had no idea whether it was installed or not...I doubt it. In my mind running wider tires up front will make a lot more difference than spacers.
2001 Boxster S 3.6L, Zeintop
01-18-2012, 05:35 PM
One downside to using spacers is that if you have a wheel out of balance or it's slightly warped, the spacers will enhance the vibration.
I can personally testify that this is true. Or well, I can attest it was true for me.
01-18-2012, 06:10 PM
The main handling result of spacers is to decrease lateral load transfer in a turn. Lateral load transfer is primarily a function of the mass, center of gravity height, and track width, with track width as the divisor in the equation.
In my experience, increasing the track width by a total of 20-30 mm can be worth about 0.2 seconds on a 60 second autocross course, and I would expect about this same results on a road course, but you will never feel it unless racing at the absolute limit.
Kippis
986S
991S
Van Diemen RF97
01-18-2012, 09:54 PM
I've got spacers on my other car and other than appearance, I don't feel any difference in handling.
Denver Steve
01-19-2012, 03:58 AM
I have the OEM 5mm spacers at all 4 corners. It makes it slightly easier to clean the Carrera Classic 19" wheel's barrel and have a little better access to clean the big reds, since the wheel is slightly out by about 1/4 inch. Other than that, you'd never notice.
