I have 15s up front and feel the front end is less twitchy, more firmly plant as a result. The tire contact patch is moved out board. The front track is slightly wider. Theoretically the roll centre(s) will move. This gives you a change in roll moment depending upon whether the distance to the longitudinal cofg axis changes
986 00S
