Old 12-29-2011, 07:57 PM   #1
What the MAF?
When i test drove the car before purchase i recall it responded to throtle flooring pretty well. Have o2 issues so haven't inspected and driven much. Changed sparknplugs and tubes, coil tubes, oil, coolant, cleaned throttle body, changed air filter, cleaned MAF couple of times using electronic cleaner. Today took it out for a long test drive and the car did not have the Porsche power. it struggled to go past 70. Disconnected the MAF and tried again. I could make it fly if i wanted to. night and day.
Am i looking at MAF replacement?
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
1990 Land Rover Defender 6x6
Old 12-29-2011, 07:59 PM   #2
Porscheectomy
Yes, that's exactly it.
Old 12-29-2011, 08:02 PM   #3
Dang! More parts to order.
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
Old 12-30-2011, 03:54 AM   #4
Is there no way to repair this thing? All it sems to have and broken is a simple diode.
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
Old 12-30-2011, 04:57 AM   #5
tonycarreon's Avatar
at this point i would just get a new one, less to worry about. the MAF is fairly important so trying to fix it (if that's even possible, which i do not believe it is) might introduce more problems, only to have it fail again in short order. the PO might have purchased a used one off of eBay for cheap to get it in working order enough to sell it...
Pelican Technical Article: Troubleshooting and Replacing the Boxster Mass Air Flow Sensor (MAF) - 986 / 987
Old 12-30-2011, 05:31 AM   #6
Johnny Danger's Avatar
You should read this thread .
CEL/Maf Cured
Old 12-30-2011, 05:36 PM   #7
CEL/Maf Cured
Thanks. I was leaning towards non OEM. Glad someone did the guinea pig thing.
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
