			Randall,thanks. The ground wire from the Subwoofer I had hooked up to the roll bar. Because it had paint the unit was not grounded which did allow sound to come through. Now that it is working, I still have to figure how to get the ignition wire tapped into the back of the fuse box. Tell me if this is right. I want to take a femal adapter and attach my Blue iginition wrie from the subwoofer and pu**************** in the back of an empyt fuse slot. The bottom wire is already there from the battery. The top slot is empyt. Then I will place a fuse in the front 7.5 amps. I hope this works. Let me know if this is correct
 thanks
 joji
