Old 11-29-2011, 07:03 AM   #1
ME5.2.2 Bench Flash Pinouts also ME7.2 required
I am currently in the process of downloading binaries from each type of DME in my vehicles and have just finished reading the ME5.2.2 from my 1999 2.5 Boxster.
It took me ages to make sure that I had the right pinouts and now have my 1st Porsche binary, using a spare ME5.2.2 ( 0261204605 ) ECU, prior to doing it on the actual car in question.
I thought that it would save someone else the time, in future, if I uploaded a pinout photo. :-)
http://www.cyberfooks.com/Porsche/Porsche-ME5.2.2-Bench-Flash-Pinouts.jpg
I used a Galletto cable and a home made Bench interface, which has an OBD2 socket, K-Line connector, L-Line connector(For older cars), 2 * +12v connectors, 2 *-12v connectors, a switched -12v connector (For putting an ECU into boot mode) and finally a switched +12v connector (Just in case)
The Pinouts for the ME5.2.2 are as follows:
+12v = pins 26 and 56 (You need to supply +12v to both of these pins)
-12v = pin 28
K-Line = pin 88
L-Line = pin 87
I am now trying to find the right pinouts to use so that I can read the ME7.2 from my 2001 Boxster S, but the only think I can really get from the workshop manuals is a rough overview of each of the 5 connectors which go into the ME7.2 ( 0261204790 ) ... Is there anyone who would be able to shed some light on the right pinouts, including the boot mode pinout?
Here is a photo of the ME7.2:
http://www.cyberfooks.com/Porsche/Porsche-ME7.2-Bench-Flash-Pinouts.JPG
2001 Boxster S - 997 GT3 bodykit, Techart Wheels, Air Suspension, 2DIN stereo-GPS-Bluetooth-Reverse numberplate camera, rear speakers, Park assist, PSM, Litronic, Porsche Crests in the headrests, Rebuilt engine-IMS upgrade,Eurocup Boxster matched tube manifolds-twin high-flow cats- twin high flow rear silencers, Short-shift kit.
1999 Boxster - Xenon dip, Main and fog, Park assist, stereo-GPS-Bluetooth, rear speakers, sub-woofer
fooksm is offline   Reply With Quote
Old 11-29-2011, 07:13 AM   #2
The Radium King's Avatar
there's some stuff here, but not what you are looking for (perhaps a place to start, however) ...
Pelican Technical Article: Boxster Engine Conversion Project - 986 Boxster (1997-04) - 987 Boxster (2005-08)
Old 11-29-2011, 09:22 AM   #3
That was, indeed, a good place to start (Thanks) as I now only need to find out which pin is K-Line and preferably which pin to program.
+12v = Pin 1/7 and pin 1/1
-12v = pin 1/6
Tags
dme , ecu , flash , me5.2.2 , motronic
