Old 08-09-2012, 12:20 PM   #21
stcroixdrew's Avatar
The outer cover pulls off......the button under....has two tabs on side that are pushed in and then it slides out. Set screw is behind...
Drew Lyons
Red Hill, Pennsylvania
St. Croix, US Virgin Islands
1998 Arctic Silver Boxster
stcroixdrew is offline   Reply With Quote
Old 07-29-2018, 05:28 PM   #22
Hello...I am a new member...I just changed all of the instrument bulbs in my 97 Boxster to green LED's, looks amazing. However, in the process I must have done something wrong. The temp gauge, gas gauge, and clock are not working now. I didn't disconect the battery when I removed the cluster. I did try to reset the computer after by disconecting the battery for 30 min then turned the key to the on position for 60 seconds. Does anyone have any idea whet I could have done and how to fix it? Thanks!
Jeffreybrucker is offline   Reply With Quote
Old 07-29-2018, 07:01 PM   #23
You didn't get the connectors seated properly. Pull them completely out, then try connecting them again. That will fix it.
Old 07-29-2018, 08:11 PM   #24
As a note, it’s now sportscarleds.com. The super white looks really cool...
