Old 11-26-2011, 07:12 AM   #1
Another Tire Question
The tire calculator at Custom rims, wheel tire packages for your ride - RIMSnTIRES.com indicates I can put a 265/35 tire on an 8 inch rim. What repercussions or negatives could I run into by doing this? I have a set of 18 x 8 square SSR-GT3 wheels I would like to put some all season tires on for the winter and trying to decide the best size tire for the rear, albeit ones readily available for a decent price. I can't find 245 or 255 35s in all season other than Firestones, which I would rather not have.
2001 Boxster S 3.6, 2003 E46 M3, 94 968 Cab, 80 911 Weissach Edition, BMW 1200 CLS
smshirk is offline   Reply With Quote
Old 11-26-2011, 09:35 AM   #2
Topless's Avatar
For the best match of tires to rims, go to the specific tire you are looking for and check the specs for recommended rim width. Here is one A/S tire and they recommend 9-10.5 wide for a 265/18 tire.
Kumho Ecsta ASX
If you get a lot of ice and snow in your area a 225 square setup would probably offer better traction than a 265.
Old 11-26-2011, 12:07 PM   #3
BYprodriver's Avatar
Kumho Ecsta ASX
265 is fine for a 8" wheel but I would recommend 265/40/18 for snow. In any case I would not go shorter than the 265/35/18 especially for you with all that low rpm torque you're sporting.
