Old 10-25-2011, 02:35 AM   #1
Spoiler Question
Hi Guys
As previously stated, just bought my first Porsche, have a question about a spoiler, does it have one???? its a 99 2.5 Boxster, it appears to have one, and what looks like a light on the dash for the spoiler, but this turns off, does it come up at a certain speed or is there a button to put it up???
Any help is appreciated
Cheers
M
McQuaid is offline   Reply With Quote
Old 10-25-2011, 03:51 AM   #2
Spinnaker's Avatar
Yes, you have a spoiler. It is just aft of the trunk lid, or the boot, as I believe it is called on your side of the pond. The red arrow in the picture shows where it is. It comes up automatically at about 75 mph and then will retract around 55 mph. There is a switch on the lower left corner of the fuse panel that will raise and lower it manually. The light on dash comes on at first startup as a check. It will go off as soon as the car starts to move.
Old 10-25-2011, 05:45 AM   #3
The spoiler will raise automatically at 75 mph (according to the manual).
Spoiler safely,
Alex
alemar is offline   Reply With Quote
Old 10-25-2011, 07:06 AM   #4
ahhhh.......the button seemed to have dissappeared into fuse box but can still press gently to go up and down, unsure wether its going up at 75 as it was very stiff and dry when going up/down
But it works anyway
Cheers guys
Old 10-25-2011, 09:03 AM   #5
Opposed to Subie Burble
Overdrive's Avatar
If you ever see that light on while in motion or not turning off after you've driven faster than 3mph, it means you've got a problem and the spoiler's not operating correctly. Otherwise, Spinnaker's explanation has you covered.
And if you have an owner's manual, I suggest giving that a read. This, along with many other helpful bits of info, is in there.
-O/D
IMSR + RMS
Robbins glass window top
